Question about Camry Relay
I have changed my fuel pump relay but car does not want to start. I connect the fuel pump to the battery via a cut of switch and the car starts. What can be the problem.
Can the fault be between the wiring of the fuel pump and the fuel pump relay or the asd relay it self
    Sergeant:
  • 462 Answers
Sounds like you have it figured good luck finding it
Posted on Mar 02, 2015
It's a 2007 Chevy Malibu LS can it be the fuel pump cost it not to crank or start
Bad fuel pump will not cause it not to crank, but can cause it not to start. Test with fuel pressure gauge. If it will not crank, entirely different issue=bad solenoid/starter, bad battery connections, bad ignition switch, relay,wiring.
May 30, 2016 | Cars & Trucks
2007 ford e350 van fuse for fuel pump location
Fuel pump relay or a FPDM - fuel pump driver module , or the inertia fuel cut off switch was tripped . F150 Expedition No Start P1233 Fuel Pump Driver Module How to test an electric fuel pump no fuel psi testing Ford
Battery junction box , under hood ! Fuse # F13 20amp. The fuel pump relay is in same box . Do you know what a relay is ?
Mar 24, 2016 | Ford Cars & Trucks
Car starts cuts
Is the engine warning light on in the dash? Need to check the codes. There is a way to do it without an analyser using the ignition switch. Varies from car to car so ask a technician.
May 29, 2014 | 2003 GMC Safari
Car will turn over but will not start changed fuel pump and main relay still no fuel.
have u checked the connection at the fuel cut off switch, also can u hear the pump running when ignition is switched on if u can hear pump ,check fuel filter for blockages
Mar 09, 2010 | 1992 Acura Integra Hatchback
1997 Suburban, cranks, won't start. Removed fuel pump and it runs when attached to battery on bench. Power at all fuses, no power on grey wire at 4 prong connector above rear axle. Is there a fuel pump cut...
The oil pressure gauge on the engine runs the fuel pump until the engine receives full oil PSI and shuts off. Upon that time the relay takes over for the fuel pump
Jan 25, 2010 | 1997 Chevrolet Suburban
No power to the fuel pump fuse 07 sportster 1200
Power to the fuel pump comes from the system relay via the fuel pump fuse. The power to the relay contact is from the ignition switch via the ECM fuse. The relay is activated with power form the ECM itself and is also controlled by the "stop/run" switch on the right handlebar control, so make sure it is switched to "run".
Apr 22, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Test for fuel cut off relay
Sam so right now you have crank no start,or no crank , no start. Not clear.
If its no crank no start.Your looking at battery, cables, ignition switch , starter relay.
If its crank no start, you know that B+ is making it to starter. Ok now listen for fuel pump to buzz or hum when you put key in ignition and turn to on position. No buzzing or humming fuel pump or relay.
make a set of jumper cables run them from battery to fuel pump, Does the pump run? If yes. The pump is good relay is not. If pump doesn't run then its the pump. Remember when you do this test you don't need the key in ignition Battery doesn't have to be connected, because your bypassing the control circuit.
Jan 24, 2009 | 1987 Honda Prelude
93 ford tempo v-6 replaced fuel pump but will not start did reset
by chance the replacement pump you used was it a "CARTER" brand I had one of those quit the same day installed it! also be sure that the feed wire on pump in tank is connected properly! you can change them by taking out the back seat of car!! the seat has 2 clips good luck
Dec 22, 2008 | 1993 Ford Tempo
Starting problem
there is a fuel pump relay under the hood in the junction box switch out the relay with the heater relay and try and start the vehicle. if it starts you know it was the relay. if it don't check the fuel cut-off switch(it's located in the trunk behind the fabric on the wheel well or under the drivers seat) push the reset button if it was tripped. if none of these is the problem check to make sure the fuse is good as well as the ecm fuse. if all these potential solutions don't pan out then your fuel pump is bad and needs replacing.....please rate this thanks
Sep 19, 2008 | 1992 Lexus Es 300
Camry Relay Logo
50 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
