Question about Sony VAIO Notebook
Sony VPCSE190x remove hard drive
I have a Sony Vaio VPCSE190x laptop and want to remove the hard drive to replace it. Upon removing the cover I notice a ribbon on the top and to the side. My other laptop did not have this. My question, do I unglued the ribbon slap out the har drive and input the new one then try and put the ribbon back on? I previously owned a VGN model which was easy snap in and out without a ribbon attached to it. I have bee unable to get support from Sony or online.
tat4u
  • 520 Answers
SOURCE: CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Posted on Mar 04, 2008
silveradoman
  • 58 Answers
SOURCE: replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
Posted on Apr 19, 2008
SOURCE: Replacement of hard disk in Vaio VGN-A150
Well, it's not good news. Official word from Sony:
Knowledge Article C309925...
Can the notebook hard drive be upgraded or replaced
Hard drive upgrades in the notebook computer are not supported.
NOTES:
* Some notebook computer have instructions for warranty replacement of the hard drive by an end user.
* Although third-party upgrades may be available for some models, they are not supported.
* If the hard drive needs service, repair should be done by an authorized Sony service center.
* External hard drives may be attached if the appropriate connections are available.
This basically means complete disassembly of the laptop is required to get at the hard drive. Not that it can't be done. Just that it'll be a major pain in the .... you know.
There is no hidden key!
Posted on Jul 25, 2008
yboyandrei
  • 828 Answers
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
Posted on Sep 02, 2009
Baytel
  • 19 Answers
SOURCE: How to remove a flickering thin green line that
It sounds like you have a bad screen or video cable.
Posted on Nov 17, 2009
SONY VAIO VPCSE190X ribbon connector
What does it connect? Have you got a photo?
Apr 10, 2014 | Computers & Internet
Sony VPCSE micro SSD
Any brand of SSD will work but once you remove the bad drive the name of the company that made it and the serial # are on it.Call me and i will contact them and get you a free replacement(225-290-5733)
Apr 02, 2014 | Sony Vaio S Series Vpcse190x...
Remove har drive
It is used to pullout the harddisk no problem if you pulled out .if placed means easy to pull out thats it.
Feb 14, 2014 | Sony Vaio S Series Vpcse190x...
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
Oct 27, 2010 | Computers & Internet
HOW TO REMOVE THE SONY VAIO VGN-N365E HARD DRIVE
This was a real pain because Sony doesn't and won't release a hardware maintenance manual. You have to take all the screws off that you see on the bottom with the little arrow next to them. Slide out the optical drive and remove the 3 screws hiding behind it. Remove the battery and take out the 3 screws behind it. Now look at the bottom of they keyboard below the row of keys with the space bar in it. There are 4 tabs that have to be pushed toward the touchpad to release the keyboard. It should swivel up now. Be careful as there is a ribbon cable behind it. Gently slide the dark brown bar away or to the right from the beige connector in the keyboard. That will release the ribbon cable. You can now see the last screw holding the top cover in place. Unscrew that screw and then you can remove the top cover. Gently pop up the edges of the top cover and work your way around. You will have to swivel the screen as far back as it goes to pop up the cover. You can just lift and move the top cover toward the screen now and reveal the hard drive. The touchpad has a smaller ribbon cable so you can choose to disconnect it if you want, but you don't have to. There are two long screws near the SATA connector that you have to remove. After taking them out, you can gently slide the drive out to the loft, caddie and all. I suggest labeling all the screws as you take them out or taping them in similar positions on a piece of paper so you can put them back in.
May 01, 2010 | Sony VAIO VGN-N365E/B Notebook
Where is HD on VGN-N250E
It's in the bottom left hand corner, as you view the laptop in it's normal position.
Sony Vaio's are not like other laptops in -> this respect.
With MOST other newer laptop's, you burn to disk your personal documents.
(Anything in your My Documents folder. My Pictures, My Music, My Videos, and personal documents you have created)
Then you buy an inexpensive external enclosure, (2.5" for laptops. And Sata for a laptop like yours), insert the new harddrive, and attach the external enclosure to your laptop, via a USB cable.
Then there is a certain key, or keys, you press on the keypad, and a menu comes up for transferring your Operating System, and programs you have installed, onto the new harddrive.
You remove the AC adapter, (Charger) and the battery.
The new harddrive is then inserted in place of the old one. Access to the harddrive, is usually removing a screw or two, then pulling the harddrive out, with part of the laptop body. Reinstall the battery, and plug the AC adapter back in. Away you go.
With the Sony Vaio series, this is not happening.
You have to use an external enclosure, and a 'mirror' imaging program, like Norton Ghost, Acronis True Image, or DriveImage XML, (Free), and mirror image the operating system, and programs to the new harddrive. (Via the external enclosure)
Then the fun(?) begins.
All electrical sources are removed. The laptop is turned over on it's top cover. Six screws are removed around the outside case edge.
One screw is removed towards the Front, and right next to the Memory Compartment Cover.
The laptop is turned back over, and a small flat tip screwdriver is inserted into slots, in front of the keypad. (Jewelers screwdriver)
The keypad is released and tilted back.
A flat ribbon cable is disconnected, from the motherboard that leads to the keypad. The keypad is removed.
Then, a small White flat ribbon cable is disconnected, in front of the keypad area. This ribbon cable connects the Front panel buttons, to the motherboard.
Now, the Top Cover is popped loose from the Bottom Cover. There is a thin parting line where the two halves meet, and a jewelers flat tip screwdriver, is inserted in this parting line towards the back. (Near the LCD screen) The Top Cover is eased up a bit, on one side, then the other side is eased up a bit. Work towards the front.
When getting to the end, (Front), the Top Cover comes off.
Now the harddrive can be seen. There are Two screws towards the Left side, in the corners. These are removed. There is One
screw towards the Right/Front corner. This is removed. The harddrive has a fabric pull 'tab' on the end of it. This is pulled on and the back end of the hardrive is gently lifted up, as it's pulled back. (Left side of harddrive is the back end)
-> Extreme caution is taken here, as there are tiny metal pins on the front off the harddrive, that can easily be bent!
There is a metal thin frame that goes around the harddrive. This is removed, by removing Two screws on each side. The metal frame goes on the new harddrive.
Apr 18, 2009 | Sony VAIO VGN-N250E/W Notebook
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
Hard disk crashed
I think it maybe mounted through to top of your laptop under the keyboard, for instructions on how to remove keyboard and sometimes the HDD is held in a carrier. click below http://www.vaio-link.com/tutorials/memory/memory.asp?l=en&category=0&serie=PCG-Z1&m=1165
Nov 01, 2006 | Sony VAIO PCG-Z1WAMP1 Notebook
Sony VAIO Notebook Logo
54 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
