Question about Dishwashers
Unable to open door think the child lock may have been puton in error
Dishlex global300
  • 8 Answers
SOURCE: child door locks
latched needs replacing
Posted on Jul 08, 2008
SOURCE: Renault Clio Rear Door Lock Fault
It has nothing to do with the "child lock" It is a know problem in this car, they tend to get caught in lock. Only thing to do, is to take of the panel then the outside handle, and through that hole destroy the plastic covering the lock, a large screwdriver and hammer will do! Then you can release the lock, while you pull the inside release handle. Buy new!
Posted on Nov 24, 2008
pittmanc
  • 194 Answers
SOURCE: Renailt megane 2000: Back door will not open
kind of hard but it can be done but what probly happen is that the child lock is hafe and hafe not ingaged or disangeged so it's stuck
Posted on Dec 05, 2008
SOURCE: outside door handler broken and child lock is on how do i open
Acura's and honda door handles are a little tricky to do.
make sure the window is all the way up.Then
1. u must remove the inside door panel.
next there is a plug on the inside edge of the door . remove this plug.
2. there is a 10mm bolt that hold the door handle on.
on some honda's and acura's door there will be a latch connecting rod. you will need a small tipped screw driver to remove this.
3. next there will be a 10mm bolt connecting the handle to the door inside. remove this bolt.
once the bolts carefully lift the handle upwards to remove the handle from the outside of the door.
At this point u can remove the door latch and other items that u wish to replace.
To install.. reverse this procedure.
Note.. is some cases there will be connecting wires to the handle and door latch itself. they must be disconnected prior to removeing and other components. Its a pain to do, but if u do not do this the connections could break and it is even harder to repair.
Take your time and don't force the parts apart. they are only plastic
Posted on Apr 25, 2009
SOURCE: cant open right rear pasenger door 2005 pathfinder
i started by removing ashtray and the screw underneath. it would be easier to remove rear seat as access is not so good to move around. wind window down, then carefully pull from top of trim, it should come away fairly easy. the trim is held on by push in clips but you need to careful as they break easy. behind the inside door handle is a plastic backing plate which i found easier to remove first. now the outside handle can be undone and i simply pulled the cable and the door opened. the cable was broken where it joins the handle so a new cable is needed.
Posted on Jul 18, 2009
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
2006 Nissan Sentra. Right passenger door wouldn't open from outside, then my kid turned on the interior child lock, meaning the door is unable to be opened from either side. Where do I go from here? C
2 or 4 door? If 2, you should still be able to use key on exterior, and I don't think they have a child lock on 2 doors, so I'm guessing 4. With car unlocked, can't you open rear doors from outside even with child lock on?
Jan 13, 2015 | 2006 Nissan Sentra 1.8
Free holden manuals
child locks are on the back doors only and are underneath the door at the trim edge around seat height. If you cannot open the door from the inside but can from the outside then it has child locks.
Aug 13, 2014 | Cars & Trucks
Renault clio forum
as child lock electronically disables rear doors central locking will not work
Jul 23, 2014 | 2006 Renault Clio 1.5
Right back door handle is broken, unable to open door
You have to get the door panel off....then you can open doot
Jan 26, 2014 | 2002 Lincoln LS
My dishlex global300 seems to fill and drain but dosnt pray to wash the dishes.... help, what can i do?
Does it leave water in the bottom after going through the wash cycle?
Jan 28, 2013 | Dishwashers
CathI have a dishlex global 510 and I cant open the door does it have a child lock and if so how do I turn it off so as I can open the door
heres what it says in your manual
Follow these steps to set the Button Lock function:
1. Switch on the appliance.
2. Set a washing program.
3. Start the washing program.
4. Press Button Lock for approximately 5 seconds, or
until the Button Lock indicator light flashes.
5. Button Lock indicator light flashes for approximately
15 seconds.
6. When Button Lock function is active the indicator
light is on with a static light.
At the end of a washing program the Button Lock function
is deactivated by opening and closing the door or
switching off the appliance.
Important! It is not possible to deactivate the Button
Lock function while a washing program is in progress
if you have any further questions message me back Thanks Rick
Jun 11, 2011 | Dishwashers
Both or my back doors do not open and i think its a child lock where would the child lock be located
If the doors open from the inside but not the outside it could be the child locks. The switch is usually located near the latch on the door. If that doesn't work, try taking it to a reputable body shop and they should be able to open the doors and diagnose the problem.
Mar 03, 2011 | 1993 Isuzu Rodeo
2002 Lincoln LS Rear door latch does not open have tha panel off tried opening manually mechanism moves but unable to open a child was playing with door lock can you help me to get the door open, would it...
I think the child safety lock is engaged. Look in your owner manual how to disengage. It is near the latch on the edge of the door. Look for the yellow label.
rotate counterclockwise to disengage child lock.
Feb 23, 2010 | 2002 Lincoln LS
Dishwashers Logo
10 people viewed this question
Top Dishwashers Experts
