Question about PNY Electronics - Others
Clear current read-only state
My PNY 64Gb USR flash drives suddenly became write protected and cannot be reset.
  • 5 Answers
SOURCE: PNY 8GB USB 2.0 Flash Drive write protection
Already covered at:
http://www.fixya.com/support/t275843-pny_optima_attache_4g
Posted on Mar 18, 2009
vishal 1419
  • 28 Answers
SOURCE: How to format write protected PNY pen drive???
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Posted on Jul 24, 2009
  • 275 Answers
SOURCE: PNY flash drive
Plug it into your USB port on the computer, works like a mini hard drive sort of. When you plug it in, it should ask what you want to do, see files etc. Just drag and drop files in or out.
Posted on Dec 04, 2009
laikexpert
  • 281 Answers
SOURCE: I have a PNY flash drive 2.0 g its read only
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flash drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 05, 2010
navin2004536
  • 63 Answers
SOURCE: How do i clear 'write protection' from a removable Flash drive?
rt click the removal drive ..properties...uncheck read only.....click on the tab security...add everyone ...give full control ...apply ..ok ...it should work now..
Posted on Mar 15, 2010
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Flash drive is only recongized as 32 GB after formatting
hi, just think sometimes to ask your questions to google, he has the answers if you look carrefully :
http://www.pny.com.tw/index.php?cls=2&mode=download
here is the direct link to the download programs page
cheers
mich
Aug 26, 2014 | PNY Turbo Plus 64GB USB 3.0 Flash Drive
Pny Attache 64gb flash drive will not format correctly
You can go to Administrative Tools>Computer Management>Disk Management and try to format it from there. You may need to delete the partition that is on there and create a new one. If you are still unable to format the drive correctly, contact the manufacturer and request a replacement.
Mar 14, 2014 | PNY Attache 64GB USB Flash Drive
My 64gb pny usb flash plug somehow got write protected without me wanting it to be... how do I change this?
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB flash drive to your computer.
Nov 05, 2013 | PNY Electronics - Others
How to fix PNY USB flash drive
Salutare bai Lucica... Vad ca ai probleme.. cu stick-ul :)
Daca ti-l vede ca unitate, in My Computer, descarca HDD Low Level Format Tool de pe http://hddguru.com/ .... descarci, instalezi si ii dai o formatare low level la stick... o sa zbarnaie dupa aceea... multa bafta
Sep 22, 2012 | PNY Attache 64GB USB Flash Drive
Find driver for pny 64g flash
Maybe the flash drive has gone bad (belly up). Try a different usb port on the computer.
Try the Flash Drive on another computer and see if it recognizes it. If not, the drive is gone bad.
You don't need drivers for it. Think about it, did you install a driver for it when you purchased it and first plugged it in? The operating system picks it up automatically and installs the drivers through windows.
But, if you want to see if there are some drivers for it, try PNY's website.
Get online and got to www.google.com In the google search box type: "PNY Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the drivers.
Jun 03, 2012 | PNY 64GB Drive
Mar 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pny Optima Attache Flash Drive suddenly locked
look for a slider on the flash drive, I had a pny flash drive that had a slider that when enabled would protect the flash drive from accidental erasure or modification of the files.
Jul 27, 2009 | Computers & Internet
Electronics - Others Logo
55 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
