Question about Sony Vaio S Series Vpcse190x Laptop/notebook W/ Bonus
Remove har drive
I need to remove the hard drive from my Sony VPCSE190X. Upon removing the cover I see a ribbon running over the top which appears to be glued on but can removed. Do I remove the ribbon then remove the hard drive and snap it into place then replace the ribbon on top? Is the ribbon important? I have been unable to find a solution to this issue. Thank you.
  • Irma Gonzalez
    Irma Gonzalez Feb 16, 2014
    It turns out the ribbon is a vital part of the hard drive connection. It is an mSATA 1.8" as opposed to 2.5" also very rare to locate.
    Habit-Forming:
  • 152 Answers
It is used to pullout the harddisk no problem if you pulled out .if placed means easy to pull out thats it.
Posted on Feb 14, 2014
Testimonial: "You mean it's not connected to an important part of the computer? It appears to be connected that's why I didn't want to touch it. Thank you! I can post a picture if you are not familiar with the model. I appreciate your kind assistance. My older VGN model didn't have the ribbon and I could easily snap it out. This looked important so had me worried."
  • Irma Gonzalez
    It turns out the ribbon is a vital part of the hard drive connection. As this model has an mSATA 1.18" as opposed to the SATA 2.5". It is easily removed, however locating the correct hard drive is near impossible. I as quoted $1,400 from Sony. Fortunately, I located my extended warranty and it will be replaced on their dime. Thank you for the help. Micro SATAs are different from regular SATA drives. This particular model was made by Samsung on a limited bases only for the VPCSE190 model. It is no longer made. Those found on the internet are used and highly priced.
lolita
  • 385 Answers
SOURCE: How To Remove My Hard Drive????????
This is a complicated process and I advise you to be very cautious and carefully organize all screws and cables that you unplug in a clean and undisturbed area. Pay keen attention as to where cables are unplugged from so you can plug them in when hard drive is inserted. I must say proceed at your own risk because it might get frustrating if you are not careful and organized. First, turn over the laptop and loose all 7 screws on the perimeter of the laptop. Loose one screw in the middle and 2 on both sides of the battery (total 10 screws). Remove the battery, there are two clips there holding the keyboard. Release those and remove the keyboard and unplug main keyboard data cable from motherboard. Unplug the power switch cable, and the touchpad cable from m/board. Unscrew 3 screws from under the keyboard to remove the top cover of laptop. When that is removed you will see the hard drive in the bottom right. There are 3 screws holding the hdd to the system and 4 holding the enclosure that needs to be removed. Unplug the sata cable and use it for new sata hard drive. I hope you have had the patience to do this as this is a job for a technician. If you have succeeded, congratulations.
Posted on Mar 19, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Removing bottom cover to replace hard drive
Here's a link for the instruction manual on replacing the hard drive.
http://esupport.sony.com/perl/model-documents.pl?mdl=PCGFRV25
Posted on Jul 24, 2008
Baytel
  • 19 Answers
SOURCE: How to remove a flickering thin green line that
It sounds like you have a bad screen or video cable.
Posted on Nov 17, 2009
  • 45 Answers
SOURCE: how to remove hard drive from sony vgn-n130g
This manual should help you
http://www.docs.sony.com/release/VGNN100series.pdf
Posted on Feb 13, 2010
TheSelkie
  • 734 Answers
SOURCE: remove the drop down icon bar on sony vaio
Usually, with a dropdown toolbar, you can put the cursor all the way to the top of the screen and with the toolbar visible, right click on it to activate a control menu from which you can stop it from dropping down, unlock it and move it to either sidr, or even turn it off altogether.
If this doesn't work, try entering yout laptop model name in Google search followed by "disable dropdown toolbar" for blogs and forums for your laptop model that may have a specific command or trick for your machine.
Good Luck
Posted on Jul 27, 2010
SONY VAIO VPCSE190X ribbon connector
What does it connect? Have you got a photo?
Apr 10, 2014 | Computers & Internet
Sony VPCSE micro SSD
Any brand of SSD will work but once you remove the bad drive the name of the company that made it and the serial # are on it.Call me and i will contact them and get you a free replacement(225-290-5733)
Apr 02, 2014 | Sony Vaio S Series Vpcse190x...
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
Oct 27, 2010 | Computers & Internet
Trying to remove an alternator from an 06 altima
Removal and Installation L4-2.5L (QR25DE) Engines To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine cover
    • Front/right-side engine undercover
    • Drive belt
    • Alternator harness connector
    • Engine ground wire from top mount
    • Alternator upper and lower mounting bolts
  3. Set the alternator aside and remove the top mount.
  4. Remove the alternator.
To Install:
  1. Slide alternator in place.
  2. Install or connect the following:
    • Alternator top mount
    • Drive belt
    • Engine cover
V6-3.5L (VQ35) To Remove:
  2. Disconnect the negative battery cable.
  3. Drain coolant from the radiator into a suitable container.
  4. Remove or disconnect the following:
    • Radiator
    • Front/right-side engine under cover
    • Drive belt
    • Idler pulley
    • Alternator adjustable top mount
    • Alternator lower mount bolt and nuts
    • Alternator lower front bracket bolt
    • Alternator harness connectors
    • Alternator
To Install:
  1. Install or connect the following:
    • Alternator in place
    • Idler pulley
    • Drive belt
    • Radiator
  2. Replace the engine coolant.
  3. Connect the negative battery cable.
  4. Start the engine and check for leaks.
  5. Recheck coolant level and top off as needed.
Oct 15, 2010 | 2006 Nissan Altima
HOW TO REMOVE THE SONY VAIO VGN-N365E HARD DRIVE
This was a real pain because Sony doesn't and won't release a hardware maintenance manual. You have to take all the screws off that you see on the bottom with the little arrow next to them. Slide out the optical drive and remove the 3 screws hiding behind it. Remove the battery and take out the 3 screws behind it. Now look at the bottom of they keyboard below the row of keys with the space bar in it. There are 4 tabs that have to be pushed toward the touchpad to release the keyboard. It should swivel up now. Be careful as there is a ribbon cable behind it. Gently slide the dark brown bar away or to the right from the beige connector in the keyboard. That will release the ribbon cable. You can now see the last screw holding the top cover in place. Unscrew that screw and then you can remove the top cover. Gently pop up the edges of the top cover and work your way around. You will have to swivel the screen as far back as it goes to pop up the cover. You can just lift and move the top cover toward the screen now and reveal the hard drive. The touchpad has a smaller ribbon cable so you can choose to disconnect it if you want, but you don't have to. There are two long screws near the SATA connector that you have to remove. After taking them out, you can gently slide the drive out to the loft, caddie and all. I suggest labeling all the screws as you take them out or taping them in similar positions on a piece of paper so you can put them back in.
May 01, 2010 | Sony VAIO VGN-N365E/B Notebook
My sony ericsson w595 turns off when i flip open it
Hi,the problem you are experiencing with your phone is as a result of a weak flex connector cable.it has to be replaced,here's a detailed solution on how to replace the cable. STEP 1. Tools required: Phillips screwdriver, plastic tool such as a guitar plectrum or credit card.
  • Remove your back cover, battery, sim and memory card.
STEP 2. Run something like a credit card under the metal plate at the top of the phone. It is stuck down tight with double sided tape but it will come away with a little force.
STEP 3
  • Starting near the top of the phone, run your credit card along the join of the front cover. When you have released the cover as much as shown below, slide the cover down to remove it (clips hold the cover on at the bottom which will be bent if you don't slide the cover off).
STEP 4 You should now have the front cover removed. Remove the small screw you can see. STEP 5
  • With the slide open halfway, lift the up the part you've just removed the screw from to reveal three ribbon connectors. Each connector has a black latch which you need to flick over the release the ribbon
  • STEP 6
  • You now have the LCD screen removed. You don't need to go any further if you only want to replace the LCD.
  • STEP 7
  • Remove the speaker and connecting ribbon etc. It's just stuck down lightly. Remove the two screws you can see at the top of the phone.
  • STEP 8
  • You now need to lift the keypad up. It's stuck down lightly with double sided tape. Remove the two screws you can see.
  • STEP 9
  • Run your credit card around the join of the grey part of the phone to release a number of clips. Turn the phone over and release a few more clips in the battery compartment.
  • STEP 10
  • Your phone should now look like below. Two small bezels (shown in the picture) will pop off when you remove the back part of the phone. Now remove the two silver screws you can see.
  • STEP 11
  • You can now remove the battery compartment. A ribbon is stuck to the side of this and will peel away quite easily. Remove the two screws you can see.
  • STEP 12
  • The circuit board will now be loose but still connected by a ribbon. Again, flick the black latch over to release the ribbon.
  • STEP 13
  • Disassembly is complete. Reverse the whole procedure for reassembly.
Apr 21, 2010 | Sony Ericsson SonyEricsson Z250i black...
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Ps3
It's less work and risk to use original Sony blu-ray laser for the Playstation 3 complete with the mechanism. this is the part you need and makes it easier to replace.
Mine cost me £54 . You will need a special hex screwdriver its a T-10 for the PS3 (Make sure its the type with a hole in the centre)
and a set of small screwdrivers .. watch makers screwdriver set is ideal.
and just some regular Philips screwdrivers .
Eject any CD, DVDs you may have in the drive turn off PS3 and disconnect all cables.
The first step is removing the top cover of the PS3 ( IMPORTANT NOT:- this will invalidate any warranty you may have ).
Place your PS3 on a none fluffy and none static cloth to protect it while working.
IMPORTANT NOTE:- Before touching anything inside your PS3 or the
replacement part , make sure that you ground any static from yourself
by touching something metal)
To remove the cover locate the small rubber lug on the left hand side of the PS3,
it is partly covered with the warranty seal. peel off the warranty seal then remove
the rubber lug with small screwdriver.
you can now remove the hex screw using the T-10 screwdriver. then slide
the top cover to the right to remove. this will reveal the main cover.
the playstation 3 main cover has arrows showing the screws needed to be removed. remove them all and note where the short screw goes . if remember correctly it the top right hand corner.
Now care fully lift the cover from the rear upwards and disconnect any ribbon or cables from the the connectors .
put the top cover to one side. the the Blu-ray drive unit can now be lifted carefully
and any ribbon cables or plugs removed from the connectors then remove from PS3
Now you can work on the Blu-ray drive unit... This is the tricky part and is where you need to be extra
carefully because you could mess up your Blu-ray drive unit. take care when removing any of the ribbons
the connectors are very delicate. lift the connector release flaps with a small screwdriver gently
and when replacing any DON'T FORCE THEM DOWN WITH ANYTHING like the tip of a screwdriver. just slide the ribbon in then gently
close the flap down with your finger. the ribbon cables have black marker lines on them so you can see if they are correctly lined up and straight.
This is a video to show what it involves..
if your not confident with type of thing I Suggest
DON'T try it! Take it to an expert.
Jul 09, 2008 | Sony Playstation 3 (PS3) Console
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Sony Vaio S Series Vpcse190x Laptop/notebook W/ Bonus Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
