Question about Dell Computers & Internet
My Touchmate wireless mouse is not working - Dell Computers & Internet
How to format touchmate tablet?
my TM-MID725 is locked because of so many pattern attempts?
Jul 08, 2012 | Computers & Internet
My touchmate mini shuffle mp3 player is not detecting in my pc suddenly and also its not playing music
Correct the date settings on the Touchmate Mini Shuffle and try reconnecting to PC. This should detect the Touchmate Mini Shuffle
Apr 07, 2012 | Audio Players & Recorders
I forgot my unlock pattern in touchmate etab..! HELP
how to unlock the user id password for touchmate etab
Mar 31, 2012 | Computers & Internet
No mouse control via wireless mouse, or touch pad
IT SOUNDS LIKE YOU HAVE MAY HAVE DRIVERS OR IRQ THAT ARE CONFLICTING, TRY UNINSTALLING THE DRIVERS FOR YOUR WIRELESS MOUSE, AND REINSTALLING THEM, MAKE SURE THE WIRELESS MOUSE IS UNHOOKED BEFORE YOU REINSTALL THE DRIVERS.
Mar 11, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Microsoft Wireless Desktop Receiver 3.1 unit which works both my keyboard and Wireless Laser Mouse 5000. My mouse is not working and I've changed the batteries 3 times. Can I buy a replacement...
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Feb 15, 2010 | Microsoft Wireless Optical Mouse USB...
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
I have a touchmate webcam which does not work any more
need a softer for my web cam (touchmate-model:tm-cam300ml)
thanks
Oct 19, 2008 | Microsoft LifeCam VX-3000 Web Camera
Computers & Internet Logo
53 people viewed this question
Alun Cox
