FixYa.com
Tags:
Lexmark X3470 All-In-One InkJet Printer
LEXMARK X 3470 (by 27 users)
posted by RODERICK328 on Oct 27, 2007
I  HAD A PROBLEM WITH THE SWITCH KEPT SAYING COVER OPEN. GOT THAT FIXED. SCANED ONCE . I STARTED TO SCAN ANOTHER TIKE AND IT CAM PARTIALY OVER THE CLASS AND THEN IT STARTED TO CLICK. NEVER SCANED ACROSS AND LIGHT NEVER CAME ON. CHECKED THE BELTS EVERYTHING GOOD WHAT COULD BE CAUSING THIS. COULD IT BE IN THE BOAD OR DOES THAT LIGHT HAVE TO COME ON TO SENSE IT WHAT IT IS DOING. IS THERE A BIOS FOR THIS PRINTER TO.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
26 Other Users Have The Same Problem
Comment by 98roadking1, posted on Jun 27, 2008
We've had that problem twice with our 3470 model in less than a year. When you change the ink cartridge, there is a small plastic part in the back that breaks. we were able to fix once. Had to change the ink cartridge and this time we can't fix. Anyone need a box to elevate their monitor? Don't know what else it's good for. Wouldn't you know, we just bought a 3 pak of new ink cartridges...
Comment by fransjan, posted on May 22, 2008
i tried to print and it said cover is open. i just opened and closed a few times and still the same. obviously a bad product. i unhooked it and have been without ever since. i'm going out to buy a different product. brand new and of no use to me at all. bought from walmart and they do'nt even carry it any longer. what does that tell you.
Comment by Guest, posted on May 22, 2008
I also get the "cover open" alarm and find the white plastic actuator arm broken. This is a new printer still with the original ink cartridge.
Funny thing is, it was working fine but I was looking it over to determine the failure mode for a friend who's identical printer was broken... and when I lifted the lid for the first time,,, the poorly designed plastic arm fell off the switch... I'm calling Lexmark and everyone else needs to too. Start with their customer support desk 1-800-5396275
Comment by Guest, posted on May 18, 2008
I have the same problem and spoke to the help desk via email the fool must know that people are having the same problem with cover is open I'm so pissed because I only use this printer three times
Comment by relbatto, posted on May 01, 2008
cover open constantly since changing the ink cartridge... powered it down by unplugging the main connection, powered the computer down and up nothing helps, this is the second lexmark 3470 ive had the problem with after changing the ink cartridge... threw the other one away...don
Best Solution
posted on Dec 15, 2007
FixYa! (100)
CACY
Rank:Apprentice Apprentice
Rating: 97%, 28 votes
Cover open problem. If you open the cover, at the back of the lid you'll find a ramp-like tab. That tab contacts a poorly designed switch in the base chassis. If you follow down where the tab goes you may find the loose plastic tab or nothing. The tab acts lie a rocker that tells the printer the lid is open for cartridge replacement. if you touch it the cartridge slide will move to the center. To clear the error, you need the cartridge tab compressed. Since you now have a broken two cent tab, you can either buy a new printer or find something to jam down there to hold it closed. Recommend a piece of balled up electrical tape. The tab is pointless and you can change the cartridge without it.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 28, 2007
FixYa! (100)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1322 votes
With the help of google here is your answer
Your arm of cover sensor has fallen off'
Try CACY solution for a great quick fix
It is the switch fallen to bits
This switch
THis bit falls off
How yours looks
How it should be, or can be if you put it together again.
It might be possible to snap the part back on without partial disassembly, or simply shove something in there to hold the sensor in the 'closed' possition (If you lose a finger or two using this method, don't blame me)
The lid sensor is a tiny microswitch that is on the main circuit board...there is a white nylon lever arm snapped onto the switch.
if the lever arm falls off (like mine did) the 'cover open' error will last forever.
This may (or may not) be possible do fix without some disassembly. This lever arm should stick up through a rectangular hole that's approximately 1/2" to the right of the print head (assuming print head is parked in the middle) and behind it.
Most likely if your lever arm has fallen off, shaking the printer gently upside down with the cover open will allow it to fall out.
Now if you are a dentist or a surgeon, snapping the lever bit back on is no problem without taking anything apart.
I am neither. For the brave (of foolish) ones who like to do surgery, here goes. Here's how I took mine apart....if yours breaks into a million bits, don't blame me.
0) unplug the power and take the scanner cover off.
1) release the 'kickstand' from the scanner by prying and squeezing it with pliers until the two prongs pop out (or crack and break)
2) detach the scanner hinges by prying/squeezing with pliers until they pop off (or crack and break). (CAUTION: read step 3 below first...don't just yank the scanner off without reading step 3)
3) Carefully unplug ribbon cable and other connector to scanner and set scanner aside.
4) remove screws at front of beige plastic part....pry at the back carefully and this will pop off....sending the screws flying if you left them loose in their little wells. Don't worry, there are only two of them that really do anything anyway.
5) Look towards the rear of the printer and you will see the circuit board and the 'hole' where you can see the sensor, and possibly your white nylon lever arm lying pathetically down in the bowels of the printer.
6) Retrieve and Carefully snap the nylon lever arm back on, and think nasty thoughts about the brainiac who designed that part.
reverse the above steps. Put at least most of the screws back in, or the front panel may fall off at a later date.
Take care to GENTLY plug the ribbon cable and the other scanner connector back in, making sure it's seated all the way. Try not to bend or kink the end of it, or it will be toast.
Good luck, and happy lexmarking.....
Comment by Soulvisitor, posted on Jan 03, 2008
Rodderick I'd say you have damaged the flat ribbon cable, they are delicate -
Solution #3
posted on Apr 13, 2008
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
piece of ****
Solution #4
posted on Mar 25, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
ok so as far as i could see i tried the picture above and my button was stuck in and still said cover open so i was in a lose lose situation fromt he beginning so i tried everything i read and nothing so i though ok you stupid thing you are coming off so i snapped it off ok not recommennded but with 2 kids screaming and dinner to be made i was annoyed anyway so i carefully snaped it off and just connected the metal connectors together if youare good a soldering you could do this but its working fine now so bypass the problem is my solution lol,
just dont blame me if you cant do it or break something you shouldnt.
good luck
Solution #5
posted on Feb 01, 2008
Not Rated (0)
dmonkey69
Rating: 0%, 0 votes
And once you do all this.....yes the "cover open" will dissappear,,,but guess what.....it wont take your paper,,,all it does it jam..... See complaints about this printer that EVERYONE who buys one is having.... go to
www.pissedconsumer.com
Solution #6
posted on Jan 18, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Hold the white plastic piece from the top with tweezers so that the way you're pinking the tweezers is the same as the way you are forcing the piece down. And push it back on by applying a lot of pressure to the tweezer with your index finger.
Can you Help with these Printers problems?
HP X3470 paper feed not working
I had to fix the cover open... Answer This...
Mode stuck on copy
The mode selector on my 3430... Answer This...
fax hp office jet j5780 hook up
i have to hook up my hp all in... Answer This...
Software Problem
Hi my name is Max. I have an... Answer This...
bad color/print quality...
the very first thing I printed... Answer This...
26 Other Users Have The Same Problem - Continued
Comment by l_wraith_l, posted on Apr 28, 2008
keeps telling me the cover is open after changing the ink cartridge
Comment by RoosterCrows, posted on Apr 13, 2008
Please read these posts. The problem starts with the door open thing. When that is FIXED, a physical problem starts with the SCANNER!
IT'S THE SCANNER THAT NEEDS ATTENTION AFTER THE SWITCH IS FIXED. There is a reset code on the front panel that did not work for me and don't remember what the process was now as I have already put this machine to it's best use as a boat anchor.
Comment by Guest, posted on Mar 30, 2008
Lexmark X3470 da o erro dizendo que a impressora es ucupada
Comment by louis1959, posted on Feb 18, 2008
the display shows "Cover Open" all the time. When I try to activate the internal RAM programming by touching START and POWER at the same time, I get the Mfg menu prompt, but that disappears as soon as I release the START and POWER keys
Comment by ashsherman, posted on Feb 18, 2008
scanner head moves just a bit and then clicks like mad. Can't even power off.  Disconnected power connector inside machine and printer works fine.
I thinks it got locked somehow. How do I fix this?
Comment by RoosterCrows, posted on Feb 17, 2008
I HAD THE EXACT PROBLEM WITH THE SWITCH KEPT SAYING COVER OPEN AFTER CHANGING INK CARTRIDGE WITH THE EXACT RESULT. I GOT THAT FIXED, NO PROBLEM, NOT THE FIRST TIME. IT WANTED TO DO AN ALIGNMENT. I STARTED TO SCAN AND IT CAME PARTIALLY OVER THE GLASS AND THEN IT STARTED TO CLICK. NEVER SCANNED ACROSS AND LIGHT NEVER CAME ON. CHECKED THE BELTS & CABLES, EVERYTHING GOOD. WHAT COULD BE CAUSING THIS PROBLEM? PRINTS FINE AFTER THE SCANNER TIMES OUT AT STARTUP. EVEN RELOADED DRIVERS.
Comment by newarkplaya1, posted on Feb 15, 2008
printer keeps saying cover open
Comment by ChetJet, posted on Feb 10, 2008
disconnected power cord. Held power and start buttons in at the same time.
Comment by Guest, posted on Feb 04, 2008
cover open
Comment by Guest, posted on Jan 09, 2008
Hello . . . my 3470 says "cover open". I've had the unit for just over the manufacturer warranty coverage (1 year ). I've printed about 100 pages so, just a bad luck situation. Before I purchase another 3470 or maybe a 2470, can you help? My e-address is jdublyuh@gmail.com
Thank you for any reply
Comment by lewisc7, posted on Jan 05, 2008
I had the same problem removed the plastic tab and taped the switch. But nowmy paper goes down and james. I removed the whole chassis and cleaned everything. The rollers where the paper feed is at rolls the paper down but the rollers down close to the ink cartridge rolls the opposite direction causing a jam.
Comment by Linkmeister, posted on Dec 09, 2007
I opened the cover to determine which cartridge I had installed, closed it, and now see a "cover open" message displayed in the LCD screen. I've lifted the cover, jiggled it, and unplugged it from the wall to no avail. The message remains "cover open."
Comment by Guest, posted on Dec 08, 2007
have just changed the ink cartridge and the machine keeps telling me that the cover is open when it is not i have already had a change over machine think this model is rip off can anyone help me
Comment by nodnod, posted on Dec 07, 2007
i've a problem the screen tells cover open and nothing is open what to do with it
Comment by Guest, posted on Dec 05, 2007
Hi all, I have the same problem, just changed the ink cartridge and Cover open, I have unplugged from electrical source and from the processor turned off it will not go away or reset. It is irritating when one has not gotten the use one would expect from a product. Not to mention the use of the ink. Thanks for letting me know when there is a solution.
Comment by Guest, posted on Nov 29, 2007
the printer kept saying cover open how do u fix it
Comment by Khamellion, posted on Nov 26, 2007
I have the same problem. I recieved this problem a year ago as a Christmas gift & after only two changes of the ink catridge mine is now saying the same thing. It's clearly not open. My mother cannot find her reciept so I cannot get a new one. I am a college student & I really can't afford to purchase another one. What do we do?
Comment by Guest, posted on Nov 25, 2007
I had the same problem. After changing the ink cartridge (for the first time) it said "Cover Open" and it was not. Lexmark sent me a new printer when it did this as they could not troubleshoot by phone. Now the new one is doing it also....and this is only the 2nd ink cartridge for this machine. Poor product. Does anyone have a solution?
Comment by dick18, posted on Nov 25, 2007
I have the same problem too. I went to change the ink cartridge and the cover thinks its opne whne it really is not. I find this odd that the 4 of us all have this same problem. any ideas out there how to fix it. I even went to Lexmark and they were stumped too.
Comment by Drahos, posted on Nov 16, 2007
Scanned some pictures. Later opened printer to change cartridge and when I close the printer, it keeps telling me the "cover is opened". It is not, but don't know how to solve the problem.
Thanks
Comment by Guest, posted on Nov 02, 2007
Lexmark X3470 scanner clicks (drive belt passing through scanner head clips) when powered up. Clicking stops eventually but scanner head will not light up or move more than an inch back and forth. Tried repositioning scanner head on belt and manually rotating head to stop position but belt will not stop moving when scanner head is nested at top of page.
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
