Question about LG DLE1310W Electric Dryer, White, Super Capacity 7.0 cu.ft., LoDecibel Quiet System, Sensor Dry System for Intelligent Fabric Care and Energy Efficiency, 5 Drying Programs, 5 Temperature Levels, WrinkCare Option, Delicates Cycle, Upfront Electronic Con
Power button not working
The dryer will not turn on or light up
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Does not respond to button press and won"t turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer Buttons Don't Work
Try unplugging it for 30 seconds or so. This may reset the board. This happens on many appliances, especially if the power went out. Hope this does the trick.
Aug 30, 2009 | Kenmore Dryers
The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Aug 27, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer light comes on but unit will not power up or turn on
Check & reset breaker in breaker box.
Your problem may be you have lost one side of your voltage coming in. Light in dryer comes on but circuit to start motor is off.
Msg back if that does not work& we will go further.
Mar 11, 2009 | LG DLEX0001TM Dryer
LG DLE1310W Electric Dryer, White, Super Capacity 7.0 cu.ft., LoDecibel Quiet System, Sensor Dry System for Intelligent Fabric Care and Energy Efficiency, 5 Drying Programs, 5 Temperature Levels, WrinkCare Option, Delicates Cycle, Upfront Electronic Con Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
