Question about Bowflex TC1000 Treadclimber
The belt is going over the belt guide
The belt on the tc1000 is going over the rear belt guides, how do I fix this
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to change oil pump on a 2004 suzuki forenza.
Here's a link on replacing your oil pump,it says to remove timing belt which means I will send a link on that too,k. Repair Guides Engine Mechanical Components Oil Pump AutoZone com Here's the second link on removing your timing belt,best to put a new belt on too. Repair Guides Engine Mechanical Components Timing Belt Sprockets AutoZone... Here's a 3rd link on removing timing belt cover. http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8037a037 Here's how to remove rear cover. Repair Guides Engine Mechanical Components Timing Belt Rear Cover AutoZone... Here's how to remove oil pan. Repair Guides Engine Mechanical Components Oil Pan AutoZone com
Aug 02, 2015 | Suzuki Cars & Trucks
Why is drive belt jumping off of rear pulley. Installed new belt this is without mower deck attached
can you turn the pulley of the rear transmission by hand? are all the idlers turnning freely? aligned well? is the belt on top of a guide pin or bar instead of under a guide?
Aug 30, 2014 | Garden
My Bowflex treadclimber Tc1000, the belts won't move, everything else is working
Motor may be disconnected or defective. Contact Bowflex for troubleshooting assistance, or they can provide an electronic copy of a service manual with troubleshooting steps.
Aug 08, 2012 | Bowflex TC1000 Treadclimber
Belt to drive cuttnig blades has come of pulleys. Does anyone know how fix? Regards, Robert
On my lawn tractors I have always been able to replace the belt by moving the big lever to make the belt go slack (the same position for the lever when you don't want the blades to turn when the motor is running)
and then putting the belt back on the pulleys. If the belt has slipped past a guide which is supposed to hold it on the pulley you may have to bend the guide, or unbolt it. If you bend it, after you get the belt back on bend the guide back close to the pulley.
good luck,
genetuck
Jan 15, 2011 | Garden
Easy way to change the drive belt on a jd lx176
There is no easy way but you can do it your self.You need to set the park brake to release belt tension and then remove the mower deck.Next step is to locate and loosen the belt guides near the trans axle pulley[may need to remove the rear wheels to get at them] and then the belt will come off.Replace the belt and reset the guides and your good to go.Merry Christmas and good luck!
Dec 24, 2009 | Garden
Disc drive slips under load & you have to jam shift arm to go rev
Check the tension on the belt tensioner....check to see if the belt guides are not under the belt anywher, rather over the top with 1/4 in clearance.....(the guides are just metal round bars either welded on or they are put on with a bolt (eye on the guides)
If the tensioner does not clear away from the belt, that would be why it shifts hard.
Apr 06, 2009 | Ariens Garden
Bowflex TC1000 Treadclimber Logo
29 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
