Question about Motorola Mobility SLVR L7 Cellular Phone
All keypad of motorola L7 does not function
What to do to repair the keypad which no longer functions
My phones keypad"s 9 no
The problem is that the rubber below the number keypad has actually gotten weak or faded away if i must say, just have it exchanged_by that i mean they will add some more rubber so that when you press the button it simply functions, it is not a big problem as such, find a phone technician and they will correct the rubber plate below your keypads okay.
Dec 11, 2010 | Motorola Mobility SLVR L7 Cellular Phone
DOES IT SLIDE OPEN AND HAVE A KEYBOARD
Motorolla L7 do not slide open and do not have keyboard, the only this it has is the keypad on the gront panel.
Motorolla L7 does not slide nor flip, it is flat phone that as all its function keys on the front panel. It does not have a keyboard either, it only has a keypad whivh is common to all phones.
Take care.
Jul 19, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Instrument got wet
I had the same problem with my slvr.I removed the battery and took a hair dryer adnspent many hours slowly drying phone.Been working for two years now!
Feb 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Keypad is not active
take the phone to a mobile repair shop and have it check the keyboard cable may not be connect properly or resting on the board properly.
Jul 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Keypad light wont turn on
It is the problem of your ribbon flex that is connector..
If you have not a good hand you cant do it. Take it to a Motorola Repair Center.
I'm sure the phone will be full functional again.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
Jan 24, 2008 | Motorola Mobility A630
Keypads
Yes, both the external keypad and the PCB assembly are relaceable. Here is one that I found online for $59 and change. http://www.cellulardr.com/0171038A01.htm . If you visit some other online resources you may find an instructional video on how to replace the PCB assembly and the tools required. Hope that helps.
Oct 28, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
