Question about Car Audio & Video
Car accelerating on its own when changing down from 4 to 3 whilst passing nuetral even with feet off all pedals. I have just got the first speeding ticket I have ever had in 46 years of driving,
  • 1 more comment
  • Bob Stevenson
    Bob Stevenson Feb 14, 2014
    Should be in the Car section and i am talking about a new Toledo
  • quinn lintorn-terry Feb 14, 2014
    if it is a new car take it back and ask the dealer to fix it. you should have warranty for it.
    what brand is the car? how old exactly is it, can you see if its a cable driven accelerator or an electrically controlled one? is it auto or manual?
  • Bob Stevenson
    Seat Toledo 1.6 Tdi 6 months old electronic throttle. also fitted with stall protection and start stop electronics I have booked an inspection since this post and have been advised that the anti stall can cause the car to accelerate on changing down.
    Scholar:
    New Friend:
  • 49 Answers
Stall protection on cars should not be making the car accelerate above a given RPM range. unless you are changing from say 3rd to 5th and when the clutch is released the rpm drops to below idle RPM the car should not be accelerating. usually stall protection automatically applies throttle only to keep itself at 1000 rpm or just below. if its operating above 1000RPM take it into the dealership and tell them its not working properly. it could just be a small sensor recalibration needed
Posted on Feb 15, 2014
Aveo 2006 has an Engine light ON and Car is shaking when trying accelerate. Car is not been able to pick up the speed with putting full pressure on the accelerator.
Yeah, it's worth it. Probably a coil pack. But this is a guess. When you take it to a garage and they diagnose it. They tell you this is the fix. They are liable.
Feb 21, 2015 | 2006 Chevrolet Aveo
Car won't accelerate with gas pedal
Transmission band slipping.
Jul 24, 2017 | 2000 Ford Focus
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
2005 Mazda 6 4cyl AT Idles high after driving a while.
I would check the pedal position sensor. Do it when it's hot.
Mazda Car 2005-06
  • Accelerator Pedal Position Sensor
    Description & Operation
    A power supply is applied on the Accelerator Pedal Position (APP) Sensor (main) power terminal from the PCM. The ground terminal is grounded with PCM. When the accelerator pedal is moved from the idle position to the fully opened position, the resistance between the accelerator pedal position sensor (main) output terminal and ground terminal will increase according to the depression.
Testing
  1. Connect a suitable scan tool to the diagnostic connector. Select APP1 or APP2 percentage.
  2. Turn the ignition switch to the ON position.
  3. Measure the voltage at the PCM terminal and ground with connectors connected:
    APP1-8% load or 0.4 volts with the accelerator pedal releasedAPP1-60% load or 3.0 volts with the accelerator pedal depressedAPP2 -8% load or 0.4 volts with the accelerator pedal releasedAPP2 -60% load or 3.0 volts with the accelerator pedal depressed
  4. If any check above does not meet the specifications, check connectors and wiring between the sensor and PCM. If ok, replace PCM.
  5. If the measured values are outside the standard value range, or if the load % and/or voltage does not change smoothly, replace the sensor.
    APP1 %-31.0-32.4% with the accelerator pedal releasedAPP1 %-69.8-81.8% with the accelerator pedal depressedAPP2 %-20.2-21.4% with the accelerator pedal releasedAPP2 %-58.8-70.8% with the accelerator pedal depressed
  5. If the measured values are outside the standard value range, or if the load % does not change smoothly, replace the senso
Jul 23, 2017 | 2005 Mazda 6
Speed Control Problem
i would have the throttle position sensor tested. and like right way
Jul 20, 2017 | 1997 Toyota Camry
MY IS IDOLING VERY FAST NEED TO USE BOTH FEET TO KEEP CAR FROM MOVING FORWARD FAST
IF YOU HAVE CARBURETOR. IDLE SPEED TOO HIGH NEED ADJUSTING. CHECK ACCELERATOR LINKAGE OR CABLE COULD BE IN A BIND CAUSING HIGH IDLE SPEED.MAKE SURE THE ACCELERATOR PEDAL FLOOR MAT NOT IN THE WAY.CHECK CARBURETOR MOUNTING BOLTS.RETIGHTEN TO MAKE YOU DONT HAVE A VACUUM LEAK BETWEEN CARBURETOR GASKET AND INTAKE MANIFOLD THAT WILL CAUSE HIGH IDLE SPEED.IF YOU HAVE FUEL INJECTION ENGINE LET A GARAGE SET THE TIMING AND IDLE.
Nov 22, 2010 | 1988 Toyota Corolla 4 Door
What is the prosedure for selecting 4wd on a jeep 1994 cherokee. do i stop and put in nuetral first or do the wheels have to be turning ?
You can put it into 4wd whilst the car is stationary or at a very slow crawling speed.To get it out of 4wd,sometimes it is slightly easier to go backwards a few feet first.Hope this helps
Aug 21, 2010 | Jeep Cherokee Cars & Trucks
How do I used the automatic gearbox?
p is for park,always put into this mode when starting up or your finished with the car.
n is for nuetral,used for warming up on very cold mornings.do not leave car unnattended EVER.
d is for drive.the car will change gear itself for a given road/engine speed(for economy use only the first1/3rd of the gas pedal travel)
3 is for accending/descending a very steep hill where
changeing from 4 to 3/3 to 4 constantly up/down would overheat the gearbox, reducing efficiency.
2 and 1 are for pulling away in snow and mud when a wheelspin would not be beneficial.
stick shift is fun but auto is more comfortable....if used considerately..
Jul 04, 2010 | 1997 Mercedes-Benz C-Class
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
