Question about JVC HD-52G886 52" Rear Projection HDTV
Hoe do i change the chanel without the remote?
Lost the remote for my Dynex and trying to connect to cable. Without the remote I cannot seem to change to chanel 3 manually, any suggestions?
Most TVs have a way of changing the channels manually. One of the buttons on the device will change the channels up or down.
May 24, 2017 | Dynex Televison & Video
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
Jun 03, 2009 | Televison & Video
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
How do I Program a Telefunken model MR702 tv without a remote
Hi got a Telefunken MR702 from a friend. No remote. How can I set the VCR and TV chanels. On Front panel left is only chanel up and volume comtrol.
Sep 05, 2008 | Televison & Video
Tv set on video
use any remote control go menu and then pres auto progam or pres any chanel like #2 or chanel 4 for exemple on tv
JOSE
Dec 22, 2007 | Sanyo DS19310 19" TV
Lack key appear on my flat screen
Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
Mar 09, 2007 | Sony 21" Trinitron P202 Flat Screen...
JVC HD-52G886 52" Rear Projection HDTV Logo
14 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
