Question about Coleman 2000004479 Personal Aluminum Led Flashlight
Changing Batteries How do you change the batteries in this flashlight?
3 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: How do you change the batteries on a Coleman
All The info I can find nothing tells us how to change the batteries. Is this a rechargable light, if so the batteries are not available for replacement. If not then the top has to screw off, or the bottom plate must screw off, there isn't any other way. What I have read is that these on this light are very hard to remove, at least that is what folks are complaining about. this light has also been discontinued and no longer availabe. if your afraid of breaking the light then I would contact Coleman for their advice since there seems to be none to be found on any bulletins they have put out.
Posted on Apr 28, 2011
I got it off. All you need is pliers. You take pliers and twist the bottom of torch with them. It'll come off in a minute or two, just keep twisting!
Posted on Feb 24, 2013
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
Can I buy a battery holder or frame for my NEBO Select flashlight?? My grandson dropped mine in the lake while changing batteries.
Given the cost and availability of those lights vs the expense for the battery carrier, you should just get a new light.
Feb 20, 2016 | Nebo Redline Select 310 Lumen Flashlight...
Light stopped working
I gather that you have checked the bulb with a meter to see if it is bad. If it is xenon high intensity then they have a short lifespan because of the heat. If that is not the problem check the batteries with a meter to see if they are good and if they are, replace the switch.
Apr 14, 2014 | Insight Technology M3 Tactical Illuminator...
HP7 does not work
LIFETIME WARRANTY. SEND IT BACK. CALL COAST, ASK FOR THE REPAIRS DEPT, AND THEN SEND IT BACK. SIMPLE.
Mar 03, 2013 | Coast HP7 High Performance Focusing 251...
Won't work after changing batteries
If the flashlight was working properly before you changed batteries, it's most likely that some tolerance is off by just a smidge so that you're not getting quite the right contact to close the circuit. You can make a thin wafer out of aluminum foil that's folded over and over onto itself and use that as a shim to increase pressure on the battery cartridge. That may be all you need.
If there is a switch on this light, as opposed to a simple screw on/screw off pressure connection, I would try checking continuity in the switch to make sure that is working correctly. Many manufacturers cut corners on the fit and construction of their flashlight swtiches, so a part can go out of alignment quickly and easily, causing failure of the switch until you can nudge those parts back in line.
Nov 25, 2012 | Leatherman Led Lenser L7 Flashlight
How do you change the batteries in the playskool flashlight
Welcome to Fixya.
To change batteries: remove the screw on the tab on the back of the flashlight. With thumb or coin, move the tab up to unsnap the battery holder. Slide out the battery holder and replace 2 C batteries.
Thanks for using Fixya.
Jul 01, 2011 | Playskool Toys
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Changing the batteries
ok the batteries almost alway go in with the positive (+) in first on all the batteries and then the end cap and thats it,  the positive side of the battery is the end of the battery that has a bump in the middle , the flat side is the negative(-)
Hope this helps you,
May 17, 2009 | MagLite Mag-Lite& Flashlight
Coleman 2000004479 Personal Aluminum Led Flashlight Logo
121 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
