Question about Coffee Makers & Espresso Machines
Shipped cafissimo classic to new base. Plugged it in and all lights are flashing what do I do to make it in normal function mode
    New Friend:
I have a same problem here. What was the solution?
Posted on Nov 21, 2017
    New Friend:
Hi, I had the same problem. Did you find the solution?
Posted on Sep 14, 2016
Power light keeps flashing when in sleep mode
It is normal -this indicates that the laptop is in "sleep" mode & NOT in shutdown mode.
Dec 04, 2013 | Acer Computers & Internet
Math functions aren't working
The new OS's (2.53 MP and higher) have the MathPrint feature. However the new feature coexists with the old one CLASSIC and you can choose one or the other.
To set that up, Press the MODE key, scroll down to go to the second page. At the top you have MathPrint and CLASSIC. Use right Arrow to highlight one othe the other then press ENTER to validate. Press [2nd][MODE] to (QUIT).
If you are in MathPrint mode, the logbase command will echo as a template with squares to fill. You enter the base in the lower square and the argument in the upper one.
If you are in CLASSIC Mode logbase appears as logBASE(. Complete the argument list by entering the number whose LOG you want separated by a comma from the base)
Example logBase(8,2) yields the value 3.
Jan 09, 2012 | Texas Instruments TI-84 Plus Calculator
Whenever i go to "Y=" and type in an equation that is "squared ", the calculator kinda zooms into that one function, visually wise, and the function has its own little box while y2, y3 and etc are under...
If you upgraded the Operating System to the 2.53 MP version or if your calculator was shipped with that version (the lastest) that is how the new OS works. It tries to imitate what you would see on a textbook. The exponents are raised above the main line and that requires more vertical space.
It is your friend who should be jealous not you.
But if that bothers you, well there is something you can do about it. Configure the calculator to use the classic (OLD) view.
  1. Press the [MODE] button.
  2. Use the Down Arrow key to move cursor to next page of options.
  3. On first line of new page, use the Right Arrow key to highlight CLASSIC and press ENTER.
  4. Press [2nd][MODE] to (QUIT)
  5. Press [Y=] to open function editor.
  6. Enter a function with an exponent (any exponent)
Warning: If you deactivate the MathPrint you will lose some functionalities (especially fraction manipulations).
Sep 04, 2010 | Texas Instruments TI-84 Plus Calculator
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Flashing lights on the base
I took it to a panasonic service center. They seem to recognize it and said its related to a flash ROM malfunction. Which usually needs to be replaced. In india they estimated the avg cost of replacing that to be around USD $20- $25. I have not got it fixed yet...
Sep 01, 2009 | Panasonic KX-TG9341T Cordless Phone
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
I just bought a new Vtech cordless phone, 5.8GHz, model CS5111, hooked up the new battery and the base and have been charging it now for Twenty-Two (22) hours and the red charge light is still on!!! The...
The red "charge" light comes on to indicate that the handset is inserted properly into the base. This is it's normal function. No further action is nessesary. :)
Nov 23, 2008 | Cell Phones
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
