Question about SE3010 2003010 Amp Manual Starter and Charger
I have no clips o my se-82-6 charger which wire shouldnbe negative or positive/
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
RED is always positive
Posted on Oct 09, 2014
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 6 Answers
SOURCE: Both Battery clips have come off of Schumacher
You need to connect the battery cable wires to the battery in order for the charger to "turn on" the output. If the "reverse polarity" LED lights up, switch the wires. The RED clamp goes to the + battery terminal wire, BLACK goes to the other.
Posted on Sep 22, 2013
Trying to charge battery for first time. It says connect two red connectors. Do you charge it first then connect the connector afterwards?
1. I assume this is a car battery so the first thing you do is to disconnect the vehicle cables from the battery terminals. The negative first and then the positive. The positive terminal is marked with a plus sign ...+ ... When refitting the cables to the
battery after it is charged you fit the positive cable to the positive battery terminal(+) first and fit the negative(-) last.
2. Now that the battery is unconnected from the vehicle you can fit the charging cables to the battery terminals. The charger you have should have 2 cables leading from it , a positive with a red plastic insulation on the clip and a negative cable probably with black insulation on the clip.The instructions with the charger will tell you in which order the cables are to be attached to the battery and the order you remove them. Each of the 2 cables has to be clipped onto the correct battery terminal. The positive cable(+) from the charger goes to the positive battery terminal (+)and the negative cable(-) from the charger goes to the negative battery terminal(-).
3. Once the cables from the charger are properly connected to the battery, you can plug in the charger and turn on the power.
4. Batteries generate explosive gasses when being charged and it only takes one small spark to ignite them. Don't reconnect the battery after charging for a half hour or so and make sure the area where you are charging is well ventilated.
Dec 18, 2015 | Cars & Trucks
Battery went dead put charger on battery and charger shuts off.
the reason for this may be the way you have attached the battery charger leads
charging batteries require the positive lead of the charger to be clipped to the positive terminal of the battery
likewise the negative lead of the charger goes to the negative terminal of the battery
I suspect that you are hooking positive to negative in which the charger will go into overload protection and shut down.
May 07, 2015 | Cell Phones
Missing battery leads
use meter it will give u a negative reading if your leads are backwards
Jan 07, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Car battery is dead. I have a Black and Decker Simple Start car battery recharger. I can figure out how to plug the outlet part into the wall but I do not know what to do about the part that goes onto...
You should have 2 wires with clips = one red that you clip on the Positive [ + ] post of the battery, this may be marked red on the cable. The other black clips to the Negitive [ - ] post of the battery.
Don't plug in the charger untill you clip the wires to the battery, make sure the charger is set to 12 volts. If your cherger has a cigar lighter wire just plug it in to the dash port.
May 09, 2011 | Honda Odyssey Cars & Trucks
The positive and negative clips got cut off my charger and i dont know which wire goes to which clip
Use a multimeter to determine polarity. If there is no "-" sign to the left of the reading, the red lead of the multimeter is connected to the positive wire and the black lead to the negative wire. If there is a minus next to the reading, the red lead is connected to the negative wire.
Feb 22, 2011 | Garden
Issues with Schumacher Battery Charger SE-82-6 - Schumacher 3 Position Slide Switch (8 pins) - Does anyone know how the wires hook-up to to the pins on the back of the switch?
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Nov 27, 2010 | Schumacher & Fast Charge Starter Charger
Battery
One thing that you can do and I swear it works perfectly is try fixing it with a 9volt battery. Get 2 wires and put them on the +positive and -negative connectors. Then put the other ends of the wires on the positive and negative sides of your camera. Just remember put positive with positive and negative with negative. Hold for 30 seconds and then try it again.. You can thank me later...
Aug 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
SE3010 2003010 Amp Manual Starter and Charger Logo
104 people viewed this question
Top Schumacher Vehicle Parts & Accessories Experts
Rigger
Jerry Z
Christian Krentz
Christian Krentz
Are you a Schumacher Vehicle Part and Accessory Expert? Answer questions, earn points and help others
