Question about ATI RADEON 9550 Graphic Card
Driver vga emtek - ATI RADEON 9550 Graphic Card
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: MY VGA DRIVER MODEL EMTEK
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/vga-driver-ati-zip/3000-2108_4-197323.html
Posted on May 13, 2011
Tip
Sagging handle on Emtek door lock set
My front door has a very nice Emtek cast bronze door latch set with a deadbolt. a few months ago the inside handle started sagging so I looked on line and did not see what I thought the problem might be. At any rate it turned out to be super simple so I thought I would post the fix hear with pics.
I simply removed the interior side of the lock set and found that the spring that holds the lever handle up had slipped off its stop. I simply removed the lock washer that holds it in place, re positioned the spring behind the stop and it works great now.
I am not sure how the spring slipped off, as it is quite tight but I am sure it had something to do with two ten year old boys going in and out constantly ;-)
http://i.fixya.netwrite_tip-dpvo4qigktl0w3wlwtq4dsz2-3-1.jpg
on Sep 10, 2015 | Miscellaneous
I need an emtek spanner
if you have access to a code reader plug it in wherever your plug is under dash;if you cant access it or have no idea what im talking about find an autozone near you thell scan it for free n tell you the codes look em up for you.
Jul 29, 2013 | Cars & Trucks
May 13, 2011 | ATI RADEON 9550 Graphic Card
I have an emtek key in knob lock and wont disasemble
The locks are tricky, they have special tools to make it easier, I'm not saying you can't do it, but if you can't get the knob apart, I don't know if you can get the pins in the tumbler right. Usually a pin hole in the side of the knob will release the keyset, then the ring in the back will release the tumbler, the cap on the top will release the pins, and I mean release, hang on to them, cause they fly! Put the tumbler back in without the pins, put the new key in, make sure it is right, drop the pins in one at a time, first the bottoms, they should all be the same size, then the tops will be according to the cut in the key. Or is it the other way around, drop in the springs, put the cover on, if it works the first time, you will be very lucky. Hope this helps.
Mar 20, 2010 | Top Knobs M826 Door Pull
Can't take apart an EMTEK entry set
Hope I can help! I have worked with Emtek before and some of the front plates are secured with screws from the the other side of the door. You may want to check if this is the case. if so remove the screws so you can remove the exterior plate. Best of luck. Hope this works!
Nov 18, 2008 | Hardware & Accessories
ATI RADEON 9550 Graphic Card Logo
59 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
