Fujitsu ast24lbaj split system fault codes
Flashing lights communication error
bobotfel
  • 236 Answers
SOURCE: Fujitsu split system
I you already tried the power supply reset in the unit ("off" and "on" the supply) may be there something wrong with your thermistor, out of range thermistor can cause error display (flashing LED).Or running the unit with under charge refrigerant is also one of the cause. If the unit operates but no cool at all then that is the cause of error display. Please call a qualified technician to check your unit.
Posted on Dec 31, 2007
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
just happen to me, call the service guy........... he told me to cut power for 30 minutes cause it erase memory inside machine. I did and its working........ So happy
Posted on Jan 05, 2012
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
