Question about Harman Kardon Audio Players & Recorders
Harman Kardon hk 870 - Harman Kardon Audio Players & Recorders
  • 44 Answers
SOURCE: Harman Kardon avr 1500 service manual
try here - http://www.harmankardon.com/product_support/support_detail.aspx?prod=AVR500
Posted on Dec 16, 2007
SOURCE: Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Posted on Nov 16, 2008
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Can i bluetooth pair my harman / kardon stand alone speaker with my ps3?
Harman Kardon AVR products and how to connect to devices
? 6:02
https://www.youtube.com/watch?v=3aPKTDlOlf0
Mar 11, 2010 - Uploaded by hyperconnected life
What I originally wanted was to have a bluetooth microphone that ... I have the av 1700 with harman Kardon ...
Esquire - Harman Kardon
www.harmankardon.com > Wireless > Portables
Harman Kardon
Rating: 4.7 - ‎16 reviews
Esquire is a Bluetooth®-enabled speaker with a built- in conference phone system ..... the sound will bounce and the bass gets a little nicer...but stand alone in the ... able toconnect it to my iPad Air as of yet; it will not recognize it on Bluetooth.Missing: ps3
[PDF]Owners Manual - Onyx Studio - Harman Kardon
br.harmankardon.com/...//harman-kardon/.../Owners%2...
Harman KardonBluetooth pairing mode automatically when it is turned on. NOTE: The speaker's Bluetooth device name is HK Onyx Studio and password is 0000. Introduction ...Missing: alone ‎ps3
Dec 16, 2015 | Audio Players & Recorders
Where to buy transistor for hk3480 part num 328 kca3114
Are you sure that is the part number? The HK-3480 uses a KTC3114A and is quite easy to find. Q317 and Q318 in your receiver.
Make sure you see the numbers correctly.
Jan 16, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Harman Kardon HK 3250 Receiver- how can I connect my turntable? there is no PHONO input
These depends on what model of turntable you have .
On most it can be connected on the inputs you have mentioned ,
If only , a RIAA preamp is included in it.
You may need one, if it doesnt have,
sample phono preamp:
Phonopreamps.com Home Page
can also be connected to Aux or Tape
Oct 08, 2012 | Harman Kardon HK 3250 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
Hook-up
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. have a look in manual above from page 9.
Sep 06, 2008 | Harman Kardon AVR 120 Receiver
I need the instruction manual for harman kardon AVR 240
http://manuals.harman.com/hk/Owner's%20Manual/AVR%20240%20OM.pdf
Jun 25, 2008 | Harman Kardon Audio Players & Recorders
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
