Question about Konica Minolta bizhub 200 Printer
How to reset error c3451 in konika minolta 215
  • Konica Minolta Master
  • 6,161 Answers
Clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Posted on Jan 18, 2016
5 Suggested Answers
SOURCE: error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
hope this helps
Posted on Jan 15, 2009
pineworks
  • 4041 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
  • 60 Answers
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
Posted on Feb 22, 2011
  • 81 Answers
SOURCE: Konika minolta bizhub 350 Error
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Posted on Sep 16, 2011
How to fix this error M1 in konika minolta bizhub 215?
Its a maintenance code for consumable due, check with any local service personal
Jul 21, 2017 | Konica Minolta bizhub Office Equipment &...
Konica-Minolta bizhub 215 giving c3451 error message?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 215 showing maintenance call(m2) and service call
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Apr 03, 2014 | Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
Konika minolta bizhub 350 Error c3451
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA BIZHUB C200
Jan 21, 2011 | Konica Minolta bizhub 200 Printer
Hi there.
e replacing.
Mar 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3451
hope this helps
Jan 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 200 Printer Logo
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
