Need Heating and Cooling Capacity of Mitsubishi Electric Air Conditioner Model: MUH-30SV
Have no compliance plates and all information has corroded away
koolbreezes
  • 540 Answers
SOURCE: Mitsubishi air conditioner MWH-35EB-A3
Check the webpage for manufacture specs!
Posted on Sep 01, 2008
asood23
  • 200 Answers
SOURCE: Amana air conditioner unit, model ARUF182416AA,
Looks like there is no gas in the compressor. Refill the gas.
Posted on Sep 20, 2009
hvac1960
  • 2133 Answers
SOURCE: mitsubishi electric, AIR CONDITIONER
E-6-Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify or replace sensor.
Posted on Jan 05, 2011
justinbur167
  • 257 Answers
SOURCE: please advise heating/cooling capacity for carrier
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Posted on Mar 06, 2011
SOURCE: mitsubishi r410a model puya30ma manual
where can I get a manual so that my husband stops hissing at me for misplacing it?
Posted on Aug 29, 2011
I have an older Amana Prestige ii air conditioner and I need the tonnage, serial number or model number. The tag information over time has disappeared.
Can you read the plate on the compressor? If so, you can determine the BTUs from there. Roughly 12,000 per ton.
Mar 05, 2018 | Amana Heating & Cooling
Mitsubish AC Model FDC 51 BA Q.1: what is capacity of this AC in tons? q.2: what is running current in amps?
Here is a YouTube video that helps you calculate tonnage of an AC.
The only way to know the running current if it's not on the AC info plate with all the other info is to measure it.
Calculating tonnage of your air conditioner
Oct 12, 2017 | Heating & Cooling
Q.1 : Mitsubishi AC model FDC-51BA how much capacity this AC has in tons Q.2 : What is running current in amps
Oct 12, 2017 | Mitsubishi Heating & Cooling
What is m6x06f2a btu output?
Features
  • Cooling Capacity (BTU) : 6,000 BTU
  • Maximum Cooling Amps : 5.6 Amps
  • Maximum Cooling Watts : 618 Watts
  • Heating Capacity (BTU) : 0 BTU
  • Maximum Heating Amps : 0 Amps
  • Energy Efficiency Rating : 9.7
  • PTAC : No
  • Window Type :Standard
Aug 04, 2015 | Maytag M6Q10F2A Air Conditioner
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    How many btu is this air conditioner model #FAA067P7A
    Good Afternoon Friend, this is Z. That's a great question!
    I show that your Frigidaire air conditioner FAA067P7A has a cooling capacity of 6,000 BTU's. I hope this information helps to some degree. If you need further assistance, please feel free to reconnect.
    May 25, 2014 | Frigidaire Compact Air Conditioner
    Can ypu please tell me the weight of the next chiller: MODEL: 50TJ-028-6B1YA SERIAL: 2806U15500 Or technical information Thanks
    DEAR SIR
    CARRIER STANDARD EFFICIENCY AIR-CONDITIONER,S DATA ARE GIVING BLOW:
    Specifications:
    ELECTRIC/ELECTRIC, HEATING & COOLING 50 SERIES - CONSTANT VOLUME, VERTICAL SUPPLY AND RETURN
    MODEL
    NUMBER
    NOM
    TONS
    NOM
    CFM
    NET
    COOLING
    (Btuh)
    NO.
    COOLING
    STAGES
    EER IPLV
    TOTAL
    kW
    HEATING CAPACITY (kW)
    (kW@ 460/3/60) WT
    (lbs)
    DIMENSIONS
    (in.)
    Length Width Height 50TJ028
    25
    7,200
    268,000
    9.3
    30.9
    32 / 55 / 80
    1,850
    86.125
    83.5
    47.25
    HOPE ANSWER THE QUESTION
    THANK YOU
    PLEASE VOTE1
    Sep 29, 2010 | Carrier 50TJ028 Rooftop Electric Cool Air...
    What is the refrigeramt capacity of the model
    Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
    Check out this tip that I wrote about that...
    Mitsubishi Air Conditioner Troubleshooting and Repair
    http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
    heatman101
    May 18, 2010 | Mitsubishi MXZ30TN Air Conditioner
    I have a a/c unit mitsubishi electric ms-12rv r22 when starting it on cooling or heating mode it stops after 30sec and the operating light flashes and the otdoor unit does not run the indoor unit fan stops...
    heatman101
    Apr 04, 2009 | Mitsubishi MS12TN Air Conditioner
    Aug 31, 2008 | Heating & Cooling
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
