Question about Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator
No cooling Unit has electricity to all lights and display. Can hear fan turning. Will not cool at all
2 Suggested Answers
  • 1462 Answers
SOURCE: oven will not heat?
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
Posted on Jun 13, 2007
Radiator cooling fan not spinning but spins freely. Light is displayed on instrument cluster
The cooling fan is energized by the electricity from a engine block sending unit and a relay.
If either of these is defective, the fan will not run on it's own.
The motor might also be bad, it can fail and still allow the fan to spin.
God bless your efforts.
Oct 17, 2015 | 2002 Volvo C70
03 pt cruiser turbo - cooling fan is noisy.
Most electric cooling fans are noisy. They move large volumes of air to cool the engine. You will hear this noise most predominately when the fan spools up when you are stopped at a traffic light. As long as it is working and cooling the engine I wouldn't worry about it.
Mar 24, 2012 | 2003 Chrysler PT Cruiser
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
Is the t603 and r672 part of the tv or the actual circuit breaker
Three blinks - B over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
DOES THIS ABOVE issue have anything to do with Cooling FAN?
I cannot hear the cooling fan come on when first turned on like
before THANKS
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Temperature display and "Cool" light flicker and click
It has an electrical problem, first. You (and I) won't know about needing freon until the compressor is running.
Jul 23, 2008 | Kenmore 72055 Air Conditioner
Carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Jul 20, 2008 | Carrier 38CKC036 Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Bosch B22CS80SNS (220 cu ft) Side by Side Refrigerator Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
