Give me error codes for copier nashuatec 3715+
The scanner lamp does stop at its home position
2 Suggested Answers
SOURCE: error code E21 in nashuatec 3715 photocopier
A amount Game At one look, A size 14 fits exceptionally well. And at an additional, You're trading up to size 18. What grants? Sizing is special everywhere, And streetwear sizes that you find at your favorite shop or boutique don't apply to bridal fashion. It's all a facts game -- and a tricky one at that!To be able to Sarah, A vital-Size bride is one who wears a streetwear size 14 or maybe more. In the bridal area of trading, That's a size 16 or more. As a rule, Your bridal size will be about two sizes greater than your regular size. Sarah assures us that very bridal gowns can be ordered in any size. At the same time, Most of samples that you'll find in a bridal boutique (Kleinfeld too) Appear in sizes 8, 10 and / or 12. A possibility? It just might be a little hard to visualize what it may be like on you. Should you are able to shop at Kleinfeld, You'll find an extensive regarding plus-Size gowns to sample that begin at size 16 and go up to size 24. http://persun.ca
Posted on Jul 06, 2012
Error c3100
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Jan 03, 2014 | Kyocera TASKalfa 180 Copier
Error code E21 in nashuatec 3715 photocopier
Jul 06, 2012 | Office Equipment & Supplies
I HAVE A CODE THAT DISPLAY IN MY NASHUATEC 1805D. THE CODE IS SC194
This error is related to the scanner.
Probably you have a dirty lamp or white plate.
If you are able to do it, try to take the screws of the glass and clean the lamp and mirrors with a dry cloth.
See you!
May 22, 2011 | Ricoh 6513 Copier
I am geting an error code of c3100 call for service I am geting an error code of c3100 call for...
Poor contact in the
Defective scanner
PWB.
correct operation.
Defective scanner
home position
switch.
Defective scanner
motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Oct 13, 2010 | Kyocera Copystar CS-1820 Black and White...
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
COPIER MACHINE NASHUATEC 3715+ DISPLAY ERROR CODE (E 54)
The malafunction is in the fusing unit.Cleam the fusing thermistors,thermofuses and make a copy.
May 03, 2010 | Office Equipment & Supplies
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
Problem with L1-00 refer to guide. Lock is unlocked, lamp carraig moves freely, drives out, then goes home. When moving slow it stops and gives the above error code
When your copier arise problem on scanner unite.
If your scanner is lock position please unlock
or clean saner all surface.
Dec 19, 2009 | Sharp AL-1655CS Laser Printer
Error code of sc101
Directly from service manual: Exposure Lamp Error: Insufficient white level detected when scanning the white plate. Possible cause: ? Exposure lamp defective ? SBU harness defective ? Bad connection ? Defect in optics system (dirty scanner mirror, mirror out of position, etc.) ? Lamp stabilizer board (or connector) defective ? Incorrect start position or length for white plate scanning (☛ SP4-015) ? Scanner HP sensor out of position
Jun 05, 2009 | Ricoh Aficio 1013F Copier
Error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Mar 28, 2009 | Ricoh Aficio 450 Copier
12 people viewed this question
jasbo
jasbo
