Question about Peticure Petite Pet Nail Trimmer Petite
I PLUGGED THE PEDICURE INTO THE WALL, BUT IT WILL NOT TURN ON. AM I DOING SOMETHINGWRONG?
I PLUGGED THE PEDICURE INTO THE WALL, BUT IT WILL NOT TURN ON. AM I DOING SOMETHING WRONG? I HAVE THE SWITCH ON AND OFF SEVERAL TIMES. EVERYTHING APPEARS TO BE IN PLACE, BUT IT'S JUST NOT COMING ON.
Bobbin does not turn anymore
the sewing machine needs to be checked to see if there is something
wrong with the hook and hook race.
Oct 23, 2012 | Sewing Machines
Bobbin comes out of place
try a different bobbin & see if that solves the problem
if not then the machine needs to be checked to see if there is something
wrong with the bobbin case
Jun 05, 2012 | Singer 5050 Mechanical Sewing Machine
Hi, My name is Anali and I recently purchased a Westinghouse TV from Target. I had it plugged into the wall and working one evening. The next day when I went to turn it on again the red button would...
Hi Anali. That sounds like the powersupply is bad. The tv has a one year manufactuers warranty. Take it back to Target and exchange for another one. Hope this helps.
May 27, 2011 | Televison & Video
My iPhone won't stay on
Replace battery. Mine was doing the same thing
Jul 27, 2010 | Apple iPhone 3G
My Acer Aspire 4520-5582 PC Notebook dosn't turn on. All that appears is a blank screen what do i do?
it could be a few different issues. 1st off, i advise that you try to turn it on while it's plugged into the wall and the battery is in. if it turns on, then shut it down again and leave it alone for a few hours to let the battery fully charge. if it doesn't work, then take out the battery and turn it on while it's plugged into the wall. if it turns on, you've probably got a bad battery. if not, then it's an internal issue. most likely a power supply.
if it's your power supply, google your particular computer model and how to take it apart. carefully do so, and when you remove the power supply, order a new one. i'd advise doing the same if it ends up being simply your battery. just go to the acer website and order a new battery to fit your particular model.
good luck!
Oct 07, 2009 | Acer Aspire 4520-5582 Notebook
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Finalizing disc
You're doing the right thing and you also have the manual. You are also able to see 'finalise' in the menu, so the camcorder is ready to perform the finalise function.
There are no 'hidden' steps. With your wall adapter plugged in and switched on you should be able to finalise.
Make sure you do not move the camcorder or switch off the wall adapter during finalisation - this could cause problems.
Sep 15, 2007 | Canon DC210 DVD Camcorder
CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
Peticure Petite Pet Nail Trimmer Petite Logo
24 people viewed this question
Top Peticure Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Peticure Pets - Other Expert? Answer questions, earn points and help others
