Question about Peticure Petite Pet Nail Trimmer Petite
It will not turn on
I plugged the peticure in the wall and it will not turn on. How do I fix it?
Peticure manual
Try looking up the specific model, for example I have an ACRG clipper. So search how to install a new battery for the "whatever model/ generation the tool is" peticure.
Nov 28, 2013 | Peticure Petite Pet Nail Trimmer Petite
How to fix a wall air conditionar didn't turn on.
I have panicked several times when this has happened to me. My solutions were simply to clean the filters out. Two other options are to reset breaker or reset on outlet plug. Hope your problem is as simple.
Aug 01, 2011 | Heating & Cooling
-Plugged into wall -Red LED on -Remote and side POWER ON/OFF will not turn TV on. -unplugged and waited over night then plugged in and it worked fine until later that day. TV turned itself off. Now...
Did you ever got the solution for this problem?
I have the same, I did notice that when I lift my tv from the bottom, attached to the wall support the tv turn on by itself, weird no?
Jun 22, 2011 | Samsung LN52B530 LCD TV
Hi I have error 1203 on my lexmark P4350 printer can you help
Error 1203 on a Lexmark printer indicates that the printer cartridge has a short circuit. Lexmark recommends that you resolve the issue as follows:
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Also, try cleaning the contacts where the cartridge plugs in. Could be a short there or on/in the cartridge itself.
Feb 28, 2011 | Office Equipment & Supplies
The machine will not turn on once it is plug in at the wall and turned on. the wall plug has been tested and is working. the machine is brand new.
it would b wise to ring 4 warrenty. if someone trys to fix unit could void warrenty.see how u go and please reply 4 more help
Apr 02, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Tv will not turn on
I can only suggest one solution not a fix but will work without much cost. Try a wireless outlet switch... the switch I have uses a wireless frequency much like a remote control only an on/off switch... I placed the switch on my wall and plugged in the receiver into a wall outlet, then plugged in my table lamp to the receiver. Now I just walk to the wall switch and click it and on goes the lamp without me having to physically reach under the lamp to turn it on... wish I was more help but for about 25.00 dollars (think it was 14.00 at lowes) its a working solution...
Mar 25, 2010 | Televison & Video
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Won't turn on
Sullo.
Try to unplug your system for 5 mins and plug it back into the wall. Also if there is a reset button or hole behind the player try sticking a paper clip in that hole while it is still plugged into the wall until the power light goes red or off.
These should reset things on your system
Cableguy
Dec 08, 2007 | Pioneer HTD520(R) System
Peticure Petite Pet Nail Trimmer Petite Logo
22 people viewed this question
Top Peticure Pets - Others Experts
Ross Keen
Anglia Clipper...
Tom Chichester
Are you a Peticure Pets - Other Expert? Answer questions, earn points and help others
