Iam not able to reinstall XP on CQ60-104TU model labtop. If i tried to install, it shows an error message in blue screen to check other newly installed hardware......
If you recently made any hardware upgrades check that the hardware is fully compatible with your machine.If nothing like that has been done, reboot the pc in safe mode by pressing F5. Some machines are F8. Check your programs and features for any newly installed software or updates. Remove any conflicting software or updates and restart the pc normally.
We wish you a Happy New Year.
If you have the original CD use it,it's genuine windows.
But what you get online is pirated.
Reinstall Windows XPTo reinstall Windows XP, try either of the following methods. If the first method does not work, try the second.
Note You may want to disconnect from the Internet during the installation. This helps protect you from malicious users.
Method 1: Start the reinstallation from Windows XPTo reinstall Windows XP by using Windows XP CD, follow these steps:
Start your computer.
Insert the Windows XP CD in your computer's CD drive or DVD drive.
On the Welcome to Windows XP page, click Install Windows XP.
On the Welcome to Windows Setup page, click Upgrade (Recommended) in theInstallation Type box (if it is not already selected), and then click Next.
On the License Agreement page, click I accept this agreement, and then click Next.
On the Your Product Key page, type the 25-character product key in the Product keyboxes, and then click Next.
On the Get Updated Setup Files page, select the option that you want, and then click Next.
Follow the instructions that appear on the screen to reinstall Windows XP.
If you successfully completed the reinstallation, congratulations. You are almost done. Please continue to the "After you reinstall Windows XP" section to finish.
If you received an error or if the reinstallation did not finish, try method 2.
Method 2: Repair install of Windows XP by starting your computer from the Windows XP CDNote If Windows XP was preinstalled on your computer, you may need the installation CD to reinstall. Contact your computer manufacturer to make sure that you have the installation CD for a repair installation.
To reinstall Windows XP by starting your computer from the Windows XP CD, follow these steps:
Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
When you receive the "Press any key to boot from CD" message on the screen, press a key to start your computer from the Windows XP CD.
The following message on the Welcome to Setup screen will appear:
This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER. To repair a Windows XP installation by using Recovery Console, press R. To quit Setup without installing Windows XP, press F3.
Press ENTER to set up Windows XP.
On the Windows XP Licensing Agreement screen, press F8 to agree to the license agreement.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
Follow the instructions that appear on the screen to reinstall Windows XP. After you repair Windows XP, you may have to reactivate your copy of Windows XP. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
310064 How to troubleshoot Windows XP Setup problems when you upgrade from Windows 98 or Windows Millennium Edition
Hope this helps.
Post back if you are facing any other problems pertaining to this.
Cheers!!
This issue might be due to system file corrupted.
You will face this issue again if this restore successfull.
You can fix this issue by reinstalling the OS(Windows XP)
Formating the C drive and reinstalling the XP will resolve this issue permanently.
go to the bios setup and disable the sata support in one of the inside options there and then make sure your hard disk is detected properly and then try again it will work.
That is called the BSOD (Blue Screen of Death).
try a chkdsk:
Chkdsk Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type Chkdsk C: /R at the prompt.
Or try a XP repair:
XP repair When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
