Canon pixma 2270 error p07 generalTool eeprom resetter
vulmec
  • 11 Answers
SOURCE: i have my canon pixma 1980 series... error says
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Posted on Sep 08, 2009
  • 164 Answers
SOURCE: how to reset canon pixma ip1980
Clearing printer
Turn off your computer and completely shut down.
Turn off your printer.
Disconnect all cables and electrical cords from your printer.
Make sure the electrical cord is also removed from the wall.
Wait 5 minutes and reconnect the power cord to the printer.
Then connect the printer cable from the computer to the printer.
Turn on your printer
Now reboot your computer (cold boot)
Your printer should now clear itself.
Posted on Mar 31, 2010
  • 159 Answers
SOURCE: How to resetter error p07
Hello, you may want to try the below instructions:
I hope it helps.
Good Luck!!
1. On the operator panel, press the button. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Solution 2:
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models).
* While holding the Start/Stop button, press and hold the POWER button.
* When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button).
* Press the Start/Stop button TWICE (still holding the POWER button)
* Release the POWER button.
* Wait for the LCD to display "0? (zero).
Step 2: Using Resetter / Software
Download Ressetter: http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
* Run "service_tool 1050.exe".
* Confirm detected USB-port numbers on USB port column.
* Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
* Click "platen button" on the "Clear ink counter" section. The printer will print again.
* Turn off the printer and then turn the printer on. You printer is ready for use.
Posted on Mar 01, 2011
kifuat90
  • 31 Answers
SOURCE: I have a canon pixma
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Posted on Aug 11, 2011
    • 144 Answers
    SOURCE: how solve error p07 in canon mp287
    First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
    1. Turn off the printer without pulling the power cord.
    2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
    3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
    4. When the printer entered the Service Mode, all LED will stop blinking.
    Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
    1. Insert some A4 paper, the printer will print the result.
    2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
    3. Press the "Platen" button located beside the "Main" button.
    4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
    5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
    source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
    Posted on Jul 05, 2012
    How solve error p07 in canon mp287
    Jul 05, 2012 | Office Equipment & Supplies
    Error occured/error 5100
    just reset your printer eeprop by software.type generaltool for canon mp160 and googlee it.run software,connect your printer and reset your printer eeprom.
    Jun 17, 2012 | Canon PIXMA MP160 All-In-One Printer
    Reset canon pixma mp258
    Reset Canon MP258 error 5B00 or P07
    Indications
    When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
    Resetter Canon MP258
    1. The printer must be in SERVICE MODE, the way
    2. MP258 printer is turned off and plugged the power cord.
    3. Press the STOP / RESET and hold, then press and hold the POWER button.
    4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
    5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
    6. The computer will detect NEW DEVICE, Ignore it .....
    7. This situation indicates the printer is on and ready to reset SERVICE MODE.
    8. Download ServiceTool_V1074 for MP258
    9. Extract file ServiceTool_V1074
    10. Prepare 2 paper in the printer (this is to print at the time the reset process)
    11. Run the program ServiceTool_V1074
    12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
    13. Click " EEPROM Clear ".
    14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
    "TPAGE(TTL=00000 COPY=00000)"
    15. Turn off the printer by pressing the POWER button or unplug the power cable
    16. Turn on the printer, and the printer ready to use
    I hope this information helps. Thank you for using FixYa!
    Oct 16, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Canon pixma mp258 error 5B00
    Please go to the following website which describes the procedure needed to fix your printer. You will need to download a resetter, the link to everything is in the instructions:
    http://ekohasans.blogspot.com/2011/02/how-to-fix-mp258-p07-error-5b00.html
    Sep 07, 2011 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
    My canon pixma ip1200 printer ink cartridge not recognize and waste ink absorber full
    Replace a new cartrige. Then try to reset printer absorver permanently-
    1.First, download the resetter software that the user majorhazard let the link.
    (http://canontips.blogspot.com/2009/02/canon-pixma-ip1200-ip1600-ip2200.html here`s the link by the way.
    2.use the regular steps to reset temporal,unplugged the cable, press and hold the power button, reconect the power cable, while holding the power button, press reset button 3 times, turn the printer on.
    3.here are the another steps to reset permanently
    1.uncompress the Generaltool.exe
    2.Run GeneralTool.exe
    3.select the USB PORT of the printer
    4.hit or click on LOCK RELEASE
    5.check the checkboks CLEANING and also EEPROM CLEAR
    6.click in the model of printer (My case IP12000e)
    7.Click MAIN and PLATEN
    8.Click TEST PATTERN 1.
    9. that`s all.
    10. If you wanna be sure that works just unplugged the printer and reconect(Power cable.)
    Thank you
    Jun 16, 2011 | Canon PIXMA iP1200 Photo Printer
    How to solve 5100 error of canon pixma ip1880 series printer
    Follow this procedure:
    1. Enter Service Mode: Hold Power button and plug a power cord, then push Resume button twice and release all buttons.
    2. Free Download from Internet: GeneralTools for Canon Pixma IP1880
    3. Starting GeneralTools
    4. CHANGE USB PORT change into PORT of your printer
    5. click lock release
    6. click ip1800
    7. click device id
    8. clear waste ink counter by clicking MAIN & PLATEN
    9. Check EEPROM Box
    10. Click EEPROM Dump
    Power off printer and all done. Work again!
    Jan 11, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
    Waste ink absorver is full problem canon pixma ip 1200 printer. How can solved is problem
    * Download General Tool for Canon iP1200, iP1600, 2200 Printers. Download GeneralTool
    * Extract downloaded file the run the software by click GeneralTool.exe.
    * Select the connected usb port number from usb port then click lock Release then select the applicable model name in set destination setting.
    * In clear waste ink counter, click main to reset the main waste ink counter or platen to reset the platen waste ink counter.
    http://downloads.ziddu.com/downloadfile/11558413/resetterforip1600.rar.html
    http://canon-printer-resetter.blogspot.com/2009/01/canon-pixma-ip1200-ip1600-ip2200.html
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 02, 2010 | Canon PIXMA iP1200 Photo Printer
    THE INK ABSORVER IS FULL
    Resetter canon iP 1700 and iP1300
    Step 1 : Reset Hardware
    1. Turn off Canon Pixma iP1700, iP1300 Printers
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
    8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
    Step 2 : Using software resetter
    1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
    2. Ekstrak/Unrar/Unzip the Software
    3. run GeneralTool.exe
    4. Select USB Port where the canon ip1300 or canon ip1700 installed.
    5. CLick Lock Release button
    6. Select EEPROM CLEAR
    7. Click Test Pattern 1 button
    8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
    Resetting Ink-Waste Ov
    Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
    I have replaced my ink cartridges because the printer said they were empty. They were not. The printer also said it couldn't find the printer head or something...what do we do now to reestablish our...
    1. Run generaltool.exe or the application or executable file.
    2. Select USB port of the printer to be reset.
    3. Click lock release button.
    4. IN Select Destination option, select the printer model.
    5. In Test Print option, select EEPROM clear.
    6. Prepare a paper and then click test pattern 1 under Test Print option.
    7. Turn off the printer and turn on again.
    For resetter which do not have Lock Release button
    3. In Select Destination option, select the printer model.
    4. In Test Print option, select EEPROM clear.
    5. Prepare a paper and then click test pattern 1 under Test Print option.
    6. finish it
    Oct 21, 2009 | Canon PIXMA MP470 All-in-One Printer
    15 people viewed this question
    k24674
    jasbo
    jasbo
