Question about Canonical Ltd. Ubuntu
Floppy drive not working in new Ubuntu 12.04 install
Has a dis-functional icon in go computer, no permissions, wont open or mount with diskette loaded in the drive with JPEG images, if detect media, I only get a continuous PW light on the drive but no media ever loads or opens. I have verified the diskette is good by opening the image files in a windows machine that has a floppy drive , and that works fine.
  • Canonical Ltd. Master
  • 3,320 Answers
Windows and Linux (ubuntu) have different file systems which are incompatible. You might be able to transfer the files over a network.
Posted on Mar 06, 2014
SOURCE: Missing floppy disk in 64bit ubuntu 8.10
I solved the problem now, so I hope it works for you. In the /etc/modules file, I added "floppy" top the list. I think the developers just removed the module loading for floppies because so few people need them now. This change should get the floppy module to load at boot. Note that you can also use the modprobe command to accomplish the same thing, but if you want it to load automatically upon booting, modify the /etc/modules file.
Posted on Dec 07, 2008
  • 5 Answers
SOURCE: Ubuntu Install Problem
If it is getting past the boot and the meter goes across the screen and then it goes black, then it could be a video card problem. I have seen the live cd do that but work fine after installing. Try hitting F4 and selecting "safe mode" at the boot time, right after you select the language.
Posted on Oct 21, 2008
SOURCE: Image Editor
I would recommend -- in line with the free software ideas of Linux -- The GIMP.
It's an amazingly powerful image editor. It should be installed with the default Ubuntu but, if it's not, it can be downloaded here: http://www.gimp.org/
Posted on Nov 24, 2008
SOURCE: Installing ubuntu on Raid 0
I have yet to try RAID, but i want to. Best idea I've heard was from a guy that set up the first hard drive with a small /boot partition in addition to the swap and ext3 ones... I guess that way, GRUB didn't get confused.
Posted on Sep 30, 2009
leecom72
  • 4806 Answers
SOURCE: How to get su capability, just loaded ubuntu 10.10
Start the package manager, search for the Avast program and uncheck the box to uninstall it.
If you need to run a root terminal the run the terminal, enter your password and type sudo -i at the command line>
Regards.
Posted on Dec 15, 2010
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps you
Oct 19, 2011 | Computers & Internet
How do i install a software for my computer.
Many software programs, games, and utilities have an AutoPlay feature that will automatically start the setup screen for the software program when the CD is placed in the computer. If your program, game, or utility contains this feature, run the installation through the screen that appears after inserting the disc.
If you are installing a program, game, or utility that does not contain this feature or you are installing a program from a floppy diskette, follow the below steps.
  1. Open My Computer.
  2. Within the My Computer window, open the drive that contains the installation files. For example, if the files are on a floppy diskette, open the A: drive. If they're on a CD or DVD open the D: drive or the letter of the disc drive.
  3. Within the drive that contains your files, locate either a setup or install file. Double-clicking on this file should start the installation for the program, game, or utility. If you see multiple setups or install files, try to locate the Application file or double-click each of setup or install files until you find the file that starts the installation. Many times the icons associated with the installation files have the same name.
An alternate method of starting the installation in Microsoft Windows
  1. Click Start and Run.
  2. In the Run Window, type x:\setup or x:\install where x is the letter of the drive you wish to start the installation from. For example, if you are attempting to install a program from the floppy disk drive you would type a:\setup or a:\install.
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 24, 2011 | Microsoft Windows XP Professional
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
I have an old microsoft works program. there is
You shouldn't have to do anything - if the diskettes and the disk unit are in working order they should appear in My Computer the moment you put the diskette in. If they don't (or, worse, the A unit isn't even present there all the time then the disk unit is dead, find another one.
Or find another pc with a functioning unit and copy all the files from all of them to an USB memory stick and open them in whatever pc and with whatever program you want.
Jun 19, 2010 | Computers & Internet
Apparntly I have DRLS120 SUPER DISK DRIVERS ON MY COMPUTER AND I CAN'T VIEW MY 2HD 1.44 MB FLOPPYS USING MY 31/2" FLOPPY DRIVE. How do I remove these drivers so that I can use my floppy drive?
If functioning correctly, the hardware of the Imation LS-120 devices can read/write 1.44MB diskettes, using "magnetic" hardware, and can use the built-in laser to read/write the proprietary 120MB "SuperDisk" diskettes.
What problem do you have?
How about taking the diskettes to a friend's computer, along with a USB memory-stick, and copying files from the diskettes to the memory-stick?
Oct 31, 2009 | Computers & Internet
I have just installed my first dual boot XP and Ubuntu on my old desktop. The floppy drive is recognised on XP but not on Ubuntu - What do I need to do to use it under Ubuntu 8 ?
Here are the steps to follow:
1. Click on "Applications -> Accessories -> Terminal".
2. In the terminal type "gksudo gedit" and enter the system password (you created this when installed Ubuntu). This will enable you to temporarily edit the "modules" file which is usually a read-only system file.
3. Click "Places -> Computer".
4. Click on "Filesystem".
5. Open up the directory (folder) called "Modules". It is the grey icon nearer the bottom of the list (you have to move the navigation bar down).
6. The file "Modules" should open in the "gedit" program.
7. It should look something like this:
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
fuse
lp
8. Now add the word "floppy" to the bottom of the file. It will now look like this:
fuse
lp
floppy
9. Now save the file by pressing pressing the "save" icon.
10. Exit the "gedit" program.
11. Now restart ubunutu (reboot the computer).
12. After reboot is complete, the floppy icon should be found under "Places" on the panel. Click on it to open a floppy. Remember to "unmount volume" when you remove or change the floppy. Linux will not let you change floppies like windows by just popping it out.
Hope this helps!
Oct 08, 2009 | Computers & Internet
Error c:\windows\system32\jebufij.dl could not be
sounds like you may have a bug. In most cases an anti virus should fix the prob. However, some will not. in this case you can reload windows and it will fix the prob. Do a full install, not a repair. (formatting the hard drive)
Jun 27, 2009 | Dell Dimension 8300 PC Desktop
About harddisk
If this is a newer system, this issue is the XP CD you are using doesn't have the needed hard drive controller driver it needs to see the Hard Drive.
Because this is Windows XP, you have only 2 options to resolve the issue. XP will only load a controller driver during install from one of 2 locations. Either a floppy diskette drive or from the XP Cd itself. XP has controller drivers for most systems available at the time the CD was burned, but newer systems, especially ones with SATA hard drives do not have supported drivers in XP CD images. You options are as follows:
  1. Connect a USB Floppy Diskette drive to the system, download the needed driver (If one is available) copy the extracted driver files to the root directory of a floppy diskette and put the diskette in the Floppy drive, then boot the XP CD again. The driver should load automatically if the floppy is in A: Drive when you boot to the CD.
  2. The second option requires slipstreaming the driver (Same one downloaded to a floppy in 1) into the XP image. (This takes a good bit of knowledge in bootable cd creation)
If all this seems to be quite the hassle, then install Vista,
Feb 17, 2009 | HP Computers & Internet
Floppy diskette seek failure
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
Canonical Ltd. Ubuntu Logo
62 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
Dennis Gutowski
Dennis Gutowski
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
