Question about Konica Minolta Office Equipment & Supplies
Code sc3602 when start start
  • Konica Minolta Master
  • 6,161 Answers
Model number would help
Posted on Jan 18, 2016
Need brake five digit brake code to start my car. Its a 2001 2.3 accord
Only from a Honda dealer by the look of it as they are VIN number specific.
http://automotiveandcommerciallocksmith.blogspot.ca/2012/07/emergency-engine-start-procedure-for.html#!/2012/07/emergency-engine-start-procedure-for.html
To start the engine without a programmed ignition key,
you need these items:
• Immobilizer key blank (master or valet)
(Refer to the parts catalog for the P/N, and search by
VIN for the correct blanks.)
• Key code for the vehicle
• Suitable key cutter
• Immobilizer Brake Code (This code is available on
the iN Immobilizer Code Inquiry.)
Need brake five digit brake code to start my car Google Search
Jan 26, 2017 | 2001 Honda Accord
2005 Chrysler 300 3.5 engine will not start ? WILL JUST CLICK BUT WILL NOT START GOT $7e8 ; $7e9 CODE BUT NOT SUB MENUS ?
CODES $7e8 & $7e9 ? P0xxx example. What clicks ? starter solenoid ? Relay ? etc.... Do a starter system voltage drop test ,go to youtube an check out no crank - no start videos . Also check out voltage drop testing starting system .
Dec 31, 2015 | 2005 Chrysler 300
What isthe fualt code b279a
could you confirm as OBD code sbegin with a P and have 4 numbers
Jun 12, 2014 | 2008 Toyota Prius
Hey there, how do I check the codes, how to jump
The codes have nothing to do with starting or not starting the car. No start means it is either getting no fuel or no spark. The codes are to diagnose a driveability or emission problem.
Mar 02, 2010 | 1995 Buick Regal
Sharp SF 2030 Copier ,need reset operator key code
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator. After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
Jun 04, 2009 | Sharp SF 2020 Copier
Van starts then check engine comes on sometimes.it also will sta
You need to find out what code is in the computer. Either have it scanned or flip the key on off on off on off on.(three times) The check engine light will flash to tell you the codes. ie 2 long flashes, followed by two short flashes would be code 22. It will repeat each code three times. It will start with code 12 and end with code 55. Code 12 is start code and 55 is end code. What ever codes come up between these codes, write them down and post.
Mar 06, 2009 | 1990 Dodge Caravan
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Computers & Internet
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
