Question about Facebook Social Network
******** say this faster???
Faster doesn't mean go around the block 3 more times.
What does convection cooking mean?
A convection oven cooks food with heat; much like a conventional oven. It is faster, though, as it circulates the air around inside the cavity.
So, it's faster than a conventional oven, but slower than a microwave oven.
Conventional ovens which also microwaved at the same time, have also been manufactured.
They were also faster than a conventional oven, but slower than a microwave. But they were not the same as a convection oven as they did not circulate the air.
May 28, 2016 | Microwave Ovens
Clear water at base of fridge
When the hose, where the water should flow out, is blocked, the water can come into the fridge. The cooling part should be between 5 an 7 degrees Celsius. I don't know what that is in Farenheid, but somewhere around 40. The freezer, depends on the starts, but 3 4 and 5 stars should be at -18 Celsius. lower will cost extra power and does not add anything to the quality of the food. Higher then -18 ( so -17 -16 and so on) will have impact on the time you can keep food in the freezer. The quality will decrease faster.
Look where the water should leave the inside, somewhere under the cooling element. Check if or what is blocking it.
Nov 01, 2014 | Refrigerators
03 civic heat doesn't work unless driving
no that is a water pump or a stuck thermostat. see when you are driving the coolant is going through the system which means the faster you go the faster the water pump goes and more pressure on the thermostat. you have a stuck thermostat
Dec 14, 2012 | 2003 Honda Civic
Shortest cycle takes 3 hours
Maybe its build up inside the dishwasher. A solution to this is to run one of the avaliable products for cleaning out the lime/scale/crud inside. Just because it looks clean doesn't mean that the hidden pump and lines aren't either partially clogged.or almost blocked. Is the hot water at 140 degrees? If not then the element inside may be attempting to heat the water to that minimum setting, If this doesn't help then I'd look at replacing the timer.
Aug 29, 2012 | Whirlpool ADG75601 Builtin Dishwasher
What does jumper j1h3 do
Oh, there it is in the second problem you posted. Intel 945GCZ,
Hmmm, lemme see.................Junction 1 Header 3,
Dunno, the wonderful(?) motherboard manual doesn't state it.
The Southbridge chip is an Intel 82801 (ICH7)
Right next to the 4 SATA connectors. Are talking about that jumper block with 3 pins, next to it?
LEAVE IT ALONE!
That is the BIOS configuration jumper block.
Has three pins. The outline around number 1 pin is a square.
The outlines around pins 2 and 3 are circles.
Pin 1 is towards the outside of the motherboard. Towards the I/O area.
Should be that the jumper block is on Pins 1 and 2, for normal operation.
Jun 24, 2012 | Computers & Internet
Doesn't start gas in oil
You have a crack in the engine block...the block is done for!!
May 05, 2012 | 1991 Oldsmobile Cutlass Ciera
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Intel Celeron Upgrade
I know how you feel, you want to improve your situation but not spend a lot of money, and squeeze some more out of what you already bought. You have a latop that works, no need to get rid of it. The problem is that CPUs on laptops are really not made to upgrade. The overwhelming amount of data out there tell us that it's actually just easier and sensible to buy a new one. I know that's not what you want to hear, but- 1) celeron chips are really not designed for gaming, although that doesnt mean you can play simple games on them 2) if your chip is a celeron, it means your laptop was not a high-end one that had the pentium chip plus all the other higher-end (faster) components that support it. That means that even if you bump up your celeron to one a bit faster, it will still have all the slow components around it. 3) the motherboard limits what you can do-- it will not let you upgrade to the fastest celeron out there, but will allow you to upgrade withing a narrow range of celerons. This is because as chips get faster, the companies change the way they attach to the motherboard, and newer chips dont attach to older montherboards. 4) the main determinant of gaming is your graphics card, then RAM, and these wont be affected by upgrading your CPU. 5) even if you were to replace your celeron, you'd have to pay a decent ammount for it, maybe 100 bucks, and I've seen new laptops sell for 399 to 499 entry level. For me, I'd rather scrape up the extra 300 bucks and just get a new laptop, which will have the new CPU (much faster than the fastest celeron), new graphics card, probably much more ram than your system can now support. Don't mean to rain on your parade! Good luck.
Feb 01, 2009 | Intel Celeron D 335, 2.8 GHz Processor
Facebook Social Network Logo
19 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
