Question about Canon CanoScan N640P Flatbed Scanner
Error code 0x002c0670 Canon N640P in Win XP - out of memory?
I am getting two code errors when I have never had an issue with this scanner over many years. The first is the out of memory error code above and the second is this code error when I try to calibrate 0x801f0810 printer port used by another device! I don't have a printer and nor do I use one. Basically I can't scan anything because I am locked by these errors. Any ideas from the brains trust?
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
SOURCE: scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
  • 183 Answers
SOURCE: Error code 2,155,0
It seems that the printer has communication problem with the computer. If you are sure your USB cable is good than it might be the board of the printer is faulty
Posted on Jan 03, 2010
Testimonial: "Thank you for your assistance. I replaced the 3M cable that is used with the desk top with a 1.8M one. It seems the laptop can't handle the long cable"
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
I hab Bought one USB-to-Parallel connector to connect my Canon Scanner .But I cannot able to scan .It displays Error Code 0*00070800. No scanners detected My Scanner mobel No :Canon N640P ex
I have many years of experince repairing Canon scanners so here is my suggestion.
First off I would go back to USB its faster then a parallel cable for scanning purposes. Second if your computer is a very old one then just get a usb card and install it in to your computer. Also make sure you have the latest drivers for the operating system your running. The drivers are free on Canons website. Just google Canon Canoscan N640P drivers it should take you directly to Canon's website also I would download capture perfect its free also an will function perfectly with your scanner.
When you install the newest drivers make sure your scanner is disconnected from your computer. Once the drivers are installed then attach the USB cable to your computer. You should get a message saying new drivers are being installed then reboot your computer and you should be good to go with whatever you want to scan.
I hope this helps you out.
Mar 31, 2011 | Canon CanoScan N640P Flatbed Scanner
I can not run the canon scanner n640 p ex in windows 7 while it is good working in win xp. so please help me how can i installed??
hello there
you need windows 7 driver of your cannon here the link : http://www.usa.canon.com/cusa/support choose your operating system and download the windows 7 driver of your cannon scanner
thanks
leave a comments
Mar 11, 2011 | Canon CanoScan N640P Flatbed Scanner
Error code 0x24050010 Canon scan N640P in windows 7. please please help me...
What you need to do is run the driver setup in windows XP compatibility mode.
Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows.
Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application.
It worked for me on Windows 7 ultimate.
Sep 16, 2010 | Canon CanoScan N640P Flatbed Scanner
Error code : 0x24050010 Canon scan N340P
I don't know what model of canon scanner you have, so I am unable to provide a link with the download, but try updating and reinstalling the canon scanner drivers from their website and see fi that wokrs
Jul 10, 2009 | Canon CanoScan N640P Flatbed Scanner
your's problem is error message profile not found 0x24050010 means you not configure properly so pls configure properly
Mar 17, 2009 | Canon CanoScan N640P Flatbed Scanner
No scanner detected on N640P ex scanner
I was recently faced with this same problem, with non detection of the scanner N640P ex flatbed. It has a card for the parallel port connection and was installed by a computer repairer to save me time. He said it worked, but when I got it home, it failed, even with the new driver added.
Here is what I did.
Check the ports in which are used for the scanner, mine was found to be LPT2, I changed that to LPT1.
(Be prepared to reverse these 2 if necessary).
I did a reboot and turned on the scanner and it showed it was there but refused to bring up the Toolbox to scan anything.
Next step, go the Microsoft and pick up this "Restore parVdm" this belongs in Windows System 32 and aids in the recognition of not only your scanner but other vital peripherals.
Its a microsoft fail when the parVdm does not recognise something.
I installed that as it comes down in .rar file, and rebooted, and all is working exceptionally well.
Will this work with any other OS? I have no idea. This worked for me on XP SP3 but parVdm also exists in Windows 7, 8 and Vista.
ParVdm Windows XP Service batcmd com
Aug 08, 2008 | Canon CanoScan N640P Flatbed Scanner
No software / driver to install the scanner
i have a canoscan n67ou scanner but have no driver to install. where can i get the installer?
Apr 07, 2008 | Canon CanoScan N640P Flatbed Scanner
Canon CanoScan N640P Flatbed Scanner Logo
old marine
old marine
