Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Coldspot model 52572201 water dispensor works but ice maker does not. What should I replace?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    TheMobilian
    • 8220 Answers
    SOURCE: Ice maker not working Kenmore model 106.55226400
    Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Posted on Mar 06, 2009
    • 93 Answers
    SOURCE: We have a Kenmore Coldspot
    It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
    Posted on Sep 12, 2009
    rogrrabbit
    • 986 Answers
    SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
    Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
    Posted on Nov 11, 2009
    Kenmore Coldspot 106.53592300 ice maker valve does not seem to be working. I have replaced the valves but there does not seem to be power to the ice maker water valve
    Go to page 18 on the PDF at the link here=> http://appliance911seabreeze.com/whirlpool_icemaker_troubleshooting.pdf
    and use a jumper wire to cause the water valve (Water Valve - L to V) to come on if the water valve is good. Here is an Ice Maker for your model=> HERE and a water control valve for your model HERE
    APPLIANCE911
    Aug 20, 2016 | Kenmore Refrigerators
    Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
    The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
    Mar 01, 2015 | Kenmore Refrigerators
    Does not make ice
    Either the ice maker is not calling for water or the ice maker water valve is not working, there are many different types of water valves so its very dificult to tell you what to do without a model number or picture of the valve, but generaly speaking if you VERY CAREFULLY put 120V to a water valve it should open and alow water to flow, you can try this for the valve that has a water line going to the ice maker and see if it lets water go to the ice maker, sometimes there are two valves that must open, one main valve and then another for either the water dispensor or the ice maker. a better first test might be to test the water valve for resistance across the coil and compair it to another coil and see if its close-ish. also you can test some ice makers and see if they are putting 120V to the water valve by bypassing the bimetal and causing the ice maker to go into a cycle, but again a model number is required to know what kind of ice maker you have., even a picture would help
    Feb 08, 2013 | Kenmore Sears Tempered Glass Shelf Refrig...
    Getting water
    I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
    Thanks
    Nov 25, 2009 | Kenmore Refrigerators
    The ice maker stopped making ice. Any solutions?
    A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
    Oct 23, 2009 | Kenmore Refrigerators
    When I connected a water source to the ice maker system on kenmore coldspot model 1069550780 side by side Refrigerator i get constant leaking from that area or just above it. Maybe water inlet valve or...
    Make sure your water connection is good. You may need to buy a new compression fitting if the water line is copper or use a new flex line with compression fitting built in to it. If you have a good connection check for a cracked water valve.
    Sep 27, 2009 | Refrigerators
    Kenmore coldspot top freezer auto ice maker, water
    Dear customer,
                   We suggest u to perform the following checks to solve ur problem...
    1. Check the refrigerator for level
    2. Check the ice maker for level
    3. Inspect the fill cup alignment
    4. Inspect the water supply line
    5. Test the water inlet switch
    6. Test the water inlet valve
    7. Check the shutoff arm
    8. Test the shutoff switch
    thank you..
    Apr 08, 2009 | Kenmore Refrigerators
    Compressor will not run
    mostly the relay called a PTC relay. If you have a ohm meter you can ohm out the compressor just to make sure but pretty sure the relay. ken
    Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
    Ice maker won't make ice
    The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
    Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    55 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
