Question about Epson Expression Premium XP-600 Small-in-One Inkjet Printer
My xp-800 has an 0x9a error - Epson Expression Premium XP-600 Small-in-One Inkjet Printer
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have an hp pavilion tx 2000 with windows 7. and want to install windows xp. but there is an error occur. error number is stop: 0x0000007b please need help thanks alot
This is a blue screen error associated with the registry this error should be fixed with a format and reinstall with xp if still don't work get a different copy of windows xp that doesnt have this error on the disk.
Mar 04, 2011 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Setup error & xp os suported error
You might be having a damaged disk. If you are installing windows XP, replace the installation cd. If you have windows XP already installed, a damage to your hard disk caused the error. You will therefore have to use the installation CD to scan the disk to fix errors, or install windows XP afresh.
Dec 01, 2010 | Computers & Internet
Window xp
The ScanDisk utility is not available in Windows XP. However, you can use the Error-Checking tool in Windows XP to check the integrity of your hard disk. To check for file system errors and bad sectors on your hard disk, follow these steps:
1.
Double-click My Computer, and then right-click the local disk that you want to check.
2.
Click Properties, and then click Tools.
3.
Under Error-checking, click Check Now.
4.
Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
5.
Click Start.
And please be more brief on your questions, and paste the error messages if you have them.
May 27, 2010 | Microsoft Windows XP Professional for PC
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
Error
window xp professional does not support FAT 16 thats why you need to formate xp with FAT 32 or NTFS.you wont get that error any more
Feb 26, 2009 | Microsoft Windows XP Professional With...
Epson Expression Premium XP-600 Small-in-One Inkjet Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
