Question about GPX S7796 CD Shelf System
The cd player wont open - GPX S7796 CD Shelf System
Caldine cd player wont tilt
The eject mechanism needs work and probably lubrication or a new belt.
Dec 25, 2012 | Audio Players & Recorders
My rca rs 2764 system the cd player wont open
Hi, what makes a CD player not ejecting or not opening is because the Sim tray which carries the CD inside the player when inserted is damaged and it's not performing it suppose to. o weak to function, You will need to replace the Sim tray that allows the CD go in and out...
Have a nice day...
Feb 18, 2011 | RCA Audio Players & Recorders
Clarion vrx486vd cd player wont open screen
help e find an installer for my hp dekjet 2300 series printer
Feb 16, 2010 | Clarion VRX485VD Car DVD Player
When i want to insert a cd the face wont open down,
Take the face off and use a pin to reset the player, or disconnected the battery for 1 hr that will reset the player
Then try and let me know
Thanks
Kindly rate the answer
Smith
Jul 09, 2009 | Alpine CDA-9851 CD Player
My Pioneer DEH-P835R Cd Player will play my cd but wont eject
Check in the front and you should see a small hole thats about the same diameter as a paper clip. Open up a paperclip to a straight 2 inches and poke it through the hole. It should release the door so you can get it open or at least seat the cd if thats whats making it not open.
Apr 26, 2009 | Pioneer DEH-P835R CD Changer
5 cd changer tray wont open
just opened the dvd player..took out the jammed cd and it's working properly now...saved me 55$ for a check or was advised to buy a new one costing 400 odd $!
Jan 21, 2009 | Philips CDC775 5-Disc CD Changer
Cd player wont open
Grab a paperclip straiten it out and carefully slide it into a small hole on the front of the cd-rom drive until it pops out.
If I'm being too literal then I suggest opening windows media player and playing the cd with that. I think after Windows XP Micro$oft got rid of the cd player or buried it in the windows system folders
Post back with more Data if not successful.
Sep 27, 2008 | Computers & Internet
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
CD PLAYER IN CAR WILL NOT TAKE CD'S
What the writer seems to be referring to is the same problem that I have with my 2003 Passat CD player. It keeps ejecting the CD. As quickly as you insert it, the CD player ejects it. The radio and cassette player work fine. Any ideas?
Nov 15, 2007 | Car Audio & Video
GPX S7796 CD Shelf System Logo
27 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
