Question about Worx Jaw Saw Wg307 - The Chainsaw Re-invented Jawsaw
The chain came off
How do I put the chain back on
New saw.2025,bought new and they put chain on backwards and will not cut.runs great but having problem loosening pinwheel chain adjustment.flip up lever but cannot loosen it.too tight
If you can't even loosen it to get the chain off and put it back on properly take it back to the people who put the chain on backwards. That is absolutely ridiculous that a dealer puts a chain on backwards...they probably just tightened it too much...use a bigger screwdriver as to not strip the screw. It should never be that tight...they may even have the wrong size chain on it, check the chain package too , make sure its the right one for your bar......Take it back, If they can't loosen it easier and in a reasonable amount of time or you see them forcing it, demand a new saw. Seriously.
Apr 26, 2017 | Garden
I have a replacement chain for a electric 40cm Bosch chain saw but it can't get the new one on as the chain tensioner will not go back far enough does it ever get blocked and should I take the cover off...
Take the cover off, Take the bar off. Clean it out. Put the chain around the sprocket. Put the bar on. Put the chain around the bar. Tighten the chain a bit. Put the cover on. Tighten the chain.
Feb 22, 2015 | Bosch Saw Chain for AKE 40 / 40-17 / 40-18...
How do I put the chain back on a chainsaw?
you need to loosen the nut on the side of the chainsaw and then take the cover off. Remove the bar and take the chain off. Then put the chain back on the bar being careful about the direction of the chain. Place the chain back over the sprocket and lower the bar back onto the plate making sure the hole lines up with the adjusting mechanism on the cover. After you line up them up put the nuts back on and loosely tighten them. Adjust the chain where it is almost tight and then tighten up the nuts.
Sep 20, 2014 | Poulan Garden
Chainm has popped . How do I put back on?
On the right side of the saw, where the chain disappears into the housing, there should be one or two nuts. These are what hold the Bar and Chain retainer plate on. Remove these two nuts, and the plate, the Bar, and the Chain will come off.
Now, just to put the chain Back on to the Bar, all you have to do is to LOOSEN these two nuts, and either right between them, or NEAR them is a FLAT-HEADED SCREW. Turn this screw to either LOOSEN, (retract) the Bar, or EXTEND the Bar. So, retact the bar, which loosens the chain, put the chain back on the bar, slowly extend the bar, by turning the screw, so that the chain gets tighter, then tighten back up the two nuts.
The chain should have a small amount of slack in it when you are finished. If you tighten it up too much, then it won't freely move, and will prematurely wear out your bar.
Good Luck.
Jun 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
How do you rePlace the chain on the 455 rancher?
You take the chain cover off of the bar. It is two nuts. Take them off and the cover will come off. Slide the bar toward you and the chain will become slack. You can then slide off the chain from the sprocket. To put a new one on. You will need to turn the chain adjustment back all the way to the left. Then put the chain back over the sprocket, then onto the bar. Put the chain cover back on and tighten the chain back up. Then tighten the two nuts back to tight.
Apr 03, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you put the chain back on. there does not seem to be a release button.
Need to remove the case and then you will find at the chain blade holder a screw that adjust the chain, once is release you can put back the chain and adjust.
Nov 08, 2010 | Remington Electric Chain Saw
When i put it in reverse the chain slacks up
well first off check make sure the the chain gears of inline if nt then u need to line them back inline then put chain back on check the slack in the chain if its too loose u will need tighten it up but if u cant tighten the chain up due to chain streched out then u may need to take a few links out of the chain
Sep 12, 2010 | Polaris ATV
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Fixing the chain back onto a Ryobi chainsaw
pull the barcover and bar off and you will see the clutch put the chain back on the clutch and put the bar back on and run the chain down the bar and put the cover back on and you will see a little screw in the bar cover are in front of saw by bar tighten that screw until slack is out of chain then tighten bar nuts.
Apr 04, 2009 | Garden
Worx Jaw Saw Wg307 - The Chainsaw Re-invented Jawsaw Logo
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
