Question about Ovens
Can bassano oven doors be removed so the glass can be cleaned between the 2 glass panels.
Grease spills has built up between glass panels of oven door. Client wants to know how to remove, clean and replace.
SOURCE: Removal of door
get a special key and open
Posted on Nov 13, 2007
Master_Tech
  • 770 Answers
SOURCE: KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Posted on Aug 13, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
Maytag317
  • 1136 Answers
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Posted on Jul 12, 2009
I have a bassano oven and my door has smashed i am not sure where i can buy bassono parts in qld, thanks
I believe bassano is a type or model name and likely to be little or no use when trying to locate spare parts. You will need more details, including the name of the manufacturer and possibly the serial number as well as the model number.
Appliances, like cars, are often badge engineered - where similar models are produced by the same manufacturer with slight differences in specification but named differently because they are destined for different markets.
You should find manufacturer details in the instruction book or if that is absent an experienced white appliance engineer might recognise the parent company from sight.
If all else fails it should be possible to have a replacement glass door manufactured. A local glazing expert should be able to advise you. Such things aren't cheap but neither are replacement glass oven doors and a manufactured door could even be cheaper, but of course a manufactured replacement will not be painted.
Jun 27, 2016 | Ovens
I have a bassano oven the front glass broke and need it replaced
The glass is installed from bottom up.on stoves. Call the company that makes the stove and talk to the service department for the list of parts required (glass and seals). Get the new parts and once you have it, remove the door and place it on a table. Take a photo of the screws location and remove them. Clean the tracks of the door, install seals, glass. Put the screws back.
Mar 04, 2015 | Ovens
How to clean my jen air built in oven
For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
I hope this helps.
Sep 11, 2011 | Jenn-Air JJW8530C Expressions Collection...
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do clean behind the glass on Maytag built-in oven.
You should have a 2 piece glass in your oven. What has happened is that the seal that separates the 2 pieces has come apart or is broken thus allowing air and grease in. You can take apart the glass but it will only be temporary for about 2-3 months and will get dirty again. The bad thing about it is that te more you take it apart, the more the band that separates the 2 pieces becomes out of its form, the harder to put it back together. Unless you don't mind it, I would leave it alone or just replace it and be done with it. The question I have is, is the glass cracked or has the door been bent? Normally, the glass lasts for nearly the life of the oven.
Feb 22, 2009 | Maytag Ovens
Grease in between glass on oven door
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
Feb 22, 2009 | Kenmore 47783 Electric Single Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Oven window
in your manual the is a section about how to remove the oven door. after removing the outer panel is removed by a few phillips screws around perimeter, of panel perhaps 2 for handle need to be removed depending on model. not a terribly difficult task, but take time and youll be fine
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven glass
all oven doors collect grease to some extent, depending on which pane of glass actually got dirty will determine how difficult it is. your owners manual shoudl describe how to remove the oven door, after that, layont it o nthe table and carefully reomving the screws from along bottom panel you should be able to ge tto your dirty glass, might take a few screws, just dissasmble slowly, dont overtigthen screws and above all remembrer how your taking apart for reassmbly
May 03, 2008 | Whirlpool RBS275PD Electric Single Oven
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
