Question about Transmission & Drivetrain for Ford Ranger
Automatic ford ranger idles in park when put into drive it stalls wont g0=
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 21 Answers
Sound like premature torque converter engagement .kind of like dropping the clutch on a manual trans without giving gas it will just stall .
Posted on Feb 14, 2014
Automatic ford ranger it starts then when you put it in gear it stalls.
One of the most common failures that can cause this problem that I have seen before is the Torque converter solenoid (TCC solenoid). This solenoid can stay stuck on and cause the torque converter to stay locked up, this will cause the vehicle to stall whenever it is put into gear. The vehicle will start and run fine in park or neutral but will stall out as soon as it is put into gear. This is the most common failure that can cause this.
Also a malfunctioning idle air control valve can cause this, if the valve isn't moving or responding to bump up the idle when put in gear it may cause the vehicle to stall out, the computer commands this valve to allow more air in to bump up the idle to compensate the load on theenginewhen put in gear, if it isn't moving or isnt moving fast enough the idle may be too low and could cause the engine to stall out.Have also seen bad crankshaft position sensor cause this ,as well as mass airflow sensor's ,TPS - throttle position sensor's . Your best bet , take it to a qualified repair an have it diagnosed . No guess work .
Nov 24, 2017 | Ford Cars & Trucks
My 1986 Ford Ranger stalls out after I take my foot off the gas and let it idle at an intersection even when I have it in neutral.
ngine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jun 06, 2012 | 1986 Ford Ranger 2WD
1991 ford ranger stalls when in gear...
sounds like a electrical problem somewere
Sep 16, 2009 | 1987 Ford Ranger
After driving for 15 minutes truck stalls,restarts no problem ,but trans races and stalls again. if it sits idle for 2-3 days runs again no problem ,until the 15 minute drive again .the 15 minute drive...
put a OBD II code reader on it see if it has stored any codes if not replace the TPS sensor and the MAF sensor do the replacements at different times so you don't buy one or the other for nothing
Jul 03, 2009 | 1993 Ford Ranger SuperCab
1990 Ford Probe 2.2 automatic stalls in forward, reverse OK
Sounds like a bad IAC (idle air control valve/sensor) that controls your idle when going from throttle to idle. If bad your idle will act crazy and can cause stalls easily. Pretty sure that's it.
Dec 20, 2008 | 1993 Ford Probe
Engine idling erratically
I had to replace the air by pass valve when my 1987 ford ranger supercab was doing that... good luck
Nov 29, 2008 | 1995 Ford Ranger Supercab
1991 ford probe
duck tape on the air intake. I just fixed mine. There is a crack on the intake that lets too much air in when you put it in drive that makes the car stall. Try it it works.
Nov 23, 2008 | 1990 Ford Probe
Transmission & Drivetrain for Ford Ranger Logo
134 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
