Question about Ford Vehicle Parts & Accessories
Ford ranger idels in park when shifted to drive it stalls
    New Friend:
Could be one of several different things i.e. major vacuum leak, mass air flow sensor (MAF), manifold absolute pressure sensor (MAP) or EGR valve malfunction just to name a few. Based on the year of the truck? best thing is to have the engine control management computer (ECM) scanned and checked for diagnostic trouble codes (DTCs) which should lead you in the right direction.
Posted on Feb 15, 2014
After ideling a while i try to shift into reverse or to drive and it always dies .......any tips or ideas?
engine dies when shifting into reverse or drive - Third Generation ...
www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Feb 11, 2006 - engine dies when shifting into reverse or drive ... After it dies it starts right up and idles fine in park or neutral. ... these ignition items because you weretrying to cure the stalling, or, did the stalling occur after you replaced these items? ...The only thing that kept the car running was adjusting the Idle screw up.
Engine Dies When Placed In Gear***Split from Spittybug...EFI ...
dmctalk.org > ... > MAIN FORUMS > Custom DeLoreans/Mods > EFI
Jul 5, 2012 - 18 posts - ‎4 authors
Just to give an update on my car - I've been having an issue with the car stalling when moving from Park into Reverse or Drive (I have automatic). ... I have been playing with the idle advance trying to get more ... I put in the remainder of the AT fluid I had on hand and the car never died on shifting after that.
starts but dies when shifted into drive or reverse - Suzuki Forum
Jan 26, 2016 | Cars & Trucks
Automatic ford ranger idles in park when put into drive it stalls wont g0=
Sound like premature torque converter engagement .kind of like dropping the clutch on a manual trans without giving gas it will just stall .
Feb 14, 2014 | Transmission & Drivetrain for Ford Ranger
Some times my 1984 ford f150 idels fine when its in park(some times)but when i put it in drive or reverse idel drops about 500 or so rpm sputters for a little bit and then dies. Some times it runs fine...
In general, yes. This is a carb tuning issue. Another possibility is a vacuum leak somewhere, but most likely, it's a carb issue. You'll typically see your rpm drop a bit when you put it in gear, but that it sometimes stalls out points to a carb issue.
May 20, 2010 | 1984 Ford F 150
1991 ford ranger stalls when in gear...
sounds like a electrical problem somewere
Sep 16, 2009 | 1987 Ford Ranger
1994 Ford Ranger won't shift into drive
In 9 out of 10 cases when I see this problem in the ranger, it is the planetary gear in the transmission. It is made of the cheapest metal available. It breaks usually from going to park before the truck stops or switching from reverse to drive while still rolling. Just a Idea , But I hope it isn't that . Reverse will work fine for a while, and have no forward gears.
Jan 15, 2009 | 1994 Ford Ranger Supercab
Engine idling erratically
I had to replace the air by pass valve when my 1987 ford ranger supercab was doing that... good luck
Nov 29, 2008 | 1995 Ford Ranger Supercab
Truck seems to stall while driving.
I have a 1980 GMC 3/4 ton stick shift truck and this past week my truck seems like its stalling as it drives. i had the oil and fuel filter changed this past thursday and it keeps stalling.
Oct 04, 2008 | 2001 Ford Ranger Regular Cab
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
