Question about Onkyo Audio Players & Recorders
AC inlet is broken on TX-SR875... How do I replace it?
I pushed the power cable too ******* my Onkyo receiver and the AC Inlet broke. The receiver is working fine, but I would like to replace it to avoid any fire risk. Where can I buy the AC inlet and how easy/difficult would it be to change it?
  • 30 Answers
A simple easy fix would be to hard wire it, solder a new cable in and secure it so it cannot be pulled out.
Posted on Feb 15, 2014
robotek
  • 1512 Answers
SOURCE: No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
Posted on Mar 21, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 899 Answers
SOURCE: where can I buy circuit boards for Onkyo Receiver TX-SR805.
have you checked these out , also you can contact the seller for other parts.
check it out !
http://shop.ebay.com/items/_W0QQ_nkwZonkyoQ20partsQQ_armrsZ1QQ_fromZQQ_mdoZQQ_sopZ12
Posted on Mar 15, 2009
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
Onkyo TX-SR875 Everything works fine,just no main unit display? Any ideas?
R9304 or R9310 are broken, if no light in display. This are 10 ohm resistor sitting on the board behind the volum knob in front.
Jun 09, 2012 | Onkyo TX-SR875 Receiver
Onkyo tx-sr875 no sound through hdmi.
Hello, I suggest having your receiver serviced. Thank you, Onkyo USA
Apr 13, 2017 | Onkyo TX-SR875 Receiver
Need universal remote code for ATT uverse remote for an avr Onkyo TX-SR875
hi! i do have a couple of codes here for your Onkyo 2006, 2219, 2220, 2318, 2410,5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140 hope this helps! goodluck!
Mar 07, 2010 | Onkyo TX-SR875 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Cannot get 7.1 on the onkyo tx-sr875
you can download a copy on the Onkyo website
Apr 21, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Onkyo tx sr875 NO SOUND!!!
Check speaker cables are in the right way as ONKYO amps have the conections side by side not up and down like most amps,also if you are useing hdmi leads go to the hardware set up in the menu and turn off the audio out for hdmi.
hope this helps.
CABLE GUY.
Jul 01, 2008 | Onkyo TX-SR875 Receiver
HDMI Output with my Onkyo 875 Receiver
Hello, the TX-SR875 does not support up-converting from component or S-video to HDMI. Is the model number correct? You stated the receiver is "brand new". This model is from 2007. Thank you, Onkyo USA
Mar 23, 2017 | Onkyo TX-SR875 Receiver
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
No display on my sr875 the next time i turned it on..i have no clue waht happend..it was just working fine yesterday,now, it suddenly shows one issue that needs to be resolve..i did everything i cud do but...
The 10 Ohms resistor R9304 in series with the the 44V display power supply was open.
How to find it:
Remove the to cover.
On the right hand side of the front panel you will see on the side a wide white flat cable going toward the back of the receiver.
Beside it is a 4 black wire band connecting the front panel to a 3x4cm power PCB which is parallel with the front panel inside the receiver (attached to the front frame).
It has visible on the left side a diode bridge and a fuse - above the fuse you can find the R9304, a SFR16 package (1x3.5mm) marked BrownBlackBlack.
Check continuity.Replace if open wit a 1W resistor
Good job ONKYO, save 1/3 of a penny...
For the DIY:
As an added step I replaced the R9304 with a 2W 47R resistor, replaced the series transistor regulator Q9301 (tall TO92) with a bigger package (isolated TO220) and one of the two series 22V zenners from the base - D9310 - with a 10V one.
Output voltage drops from 44V to 34V, display is slightly dimmer but overall stress is down.
Dec 14, 2007 | Onkyo TX-SR875 Receiver
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
