Question about Samsung Dryers
Dryer won't spin - Samsung Dryers
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
Won't spin
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Oct 30, 2012 | Frigidaire AEQ7000EG Affinity Series...
My maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Oct 24, 2012 | Maytag Dryers
Sears laundry center 92702 burning smell and won't drain spin out
If the motor is running and it won't drain or spin, then the motor coupler has failed and needs replacing. Here is a link to the part.
Here is a video to show you how to replace the coupler. If you could post the model number that is located on the unit I can get you the service manual to help you a little better.
Oct 18, 2012 | Sears 24 in. Electric Laundry Center with...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Dryer wont spin
About 90+% of the time when a dryer won't spin it is a broken/slipped belt.
If the dryer makes some niose when activated, then the motor is turning, which exonerates the
motor, leaving just the belt - the belt may have slipped off a (possibly broken) pulley.
Aug 03, 2011 | Kenmore 98702 Stacked Washer/Dryer
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
Sqeaks and won"t spin
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
Dryers Logo
21 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
