Question about DeLonghi Kitchen Appliances - Others
How do i take apart my delonghi CTO4003.BK toaster
I have removed 4 screws in the base and have released some twisted metal clips but cannot get the body of the toaster to come away from the base
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: Dualit 4 slice toaster.
Yes correct
Posted on Sep 01, 2010
SOURCE: I am trying to take apart the toaster, but...
You need to remove the four rubber feet at the four corners, and that's where the screws are. Get a small flathead screwdriver and pry the rubber feet out of their sockets and you'll see small screws.
Posted on Jan 08, 2011
How do I open Delonghi CTO4003 toaster
If by open you mean get the crumbs out, there are two slide trays. Pull them out rearward, dump them, and slide them back in.
Jan 17, 2015 | DeLonghi CTO4003 4Slice Toaster
Tool required to strip DeLongi 4 slice toaster
http://www.instructables.com/id/Poor-man-s-200-dollar-plastic-heat-strip-for-penni/step1/Materials-and-tools/
Sep 06, 2013 | DeLonghi CTO4003 4Slice Toaster
Just got 4 slice de longh iconai toaster and husband made toast last night in right hand side. No problem last night but this morning this side will not toast as the lever which one pushes down to keep...
I have no experience with the deLonghi toaster but in my experience automatic toaster all work in similar ways since they went electronic - toasters were about the first to do that.
Pressing the lever down against the spring pressure also presses an internal switch that sends current to the heating element as well as to the electronics that control an electromagnet, the purpose of which is to keep the mechanism engaged until the toast is brown enough and then the current to the magnet will be cut by the browning brain and the toast pops up.
If removing any crumbs from inside by inverting it and giving it a good shake and then pressing the lever a few times fairly vigorously doesn't make it work then nothing short of surgery will make it work so returning it will be the only realistic option.
Aug 22, 2017 | DeLonghi CTO4003 4Slice Toaster
How to remove battery from norelco t 800 can not get to come apart after removing 1 screw on grip
Disassembling the Norelco T800 is quite easy -- once you know what to do!
* Remove the single small Philips screw that you can see near the power connector
* Twist (hard) the cutter depth ring past 9 and it will come loose.
* Now remove both the ring and the guide piece that it moves up and down
* Now pry off the cutter head (black piece of plastic)
* Now remove the metal clip that you find under the head -- press down on the two free ends and pry the other end of the clip loose.
* Now release two plastic tabs that we under the rotating ring.
* Now I just pried the two parts apart by inserting a small screwdriver and twisting. I'm not sure if there are any more tabs that can be released at this point.
* Now you can remove the circuit board (which is held in my a couple of plastic tabs).
Now you can replace the *single* NICD 600maH battery (AA size). The longest bit of this step was heating up the soldering iron!
Reassembly is the reverse.
Philip
Nov 08, 2010 | Norelco T 800 Beard Trimmer
Wont stay down
At the moment I am looking for the problem in m,y Tefal. The biggest problem seems to be sorting out how to pull it apart. I have sfound that the whole carriage must be pulled out the back of the toaster. About 10 T10 screws to be removed from the base then there are are a couple more philips screws to remove after the back is off, then the handles that you press down to allow the bread to drop mus t be released. There are plastic pieces that hold in the metal tip on the handles. They are located inside the body and are accessewd from the slot that the handle moves in. I haven't yet located the release clips for the high lift handles. Once I have found them I may be able to access the mechanisms. If this doesn't help enough then please ask for more information as I shall have found my way inside by then
billypil
Jul 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
My 4 slice Dualit toaster stopped working! Repair?
I had an issue where it wouldn't stay down, or heat even if I held it down. No power at all.
Firstly unplug it.
To take it apart, turn it upside down. You have to get the 4 security bolts undone which are underneath (Mine look like they have six holes around them).
Also, you need to unscrew the bobble by hand which you use to push the toast down. You can then pull the cover off, from the back first. The timer dial is connected to the cover, but I didn't disconnect this.
Note: You don't need to undo the bolts inside the toaster. (They only hold the metal base to the plastic base), the 4 torx screws holding the side panel on, or the 4 twisted pieces of metal which hold the toaster internals to the base.
Inside, there are 4 prongs which are pushed together when you push the toast down. On further inspection, I found the main blue power cable had become corroded, and had melted and become disconnected. So simply unscrewed the 2 screws hold this section on,(simply for easier access) and resoldered the blue cable back onto the correct prong.
And now it works again!
May 24, 2010 | Dualit CTS4E 4-Slice Toaster
Free Agent 1000GB is heating too much and stops working and want to know how to disassemble it to install a fan.
This is from another site, but I think it has a good description
Be careful, some people report that taking these drives apart may damage the connectors, that are soldered to a circuit board inside the case.
Try these steps, I looked at my own drive and it looks like it has the same design as the one described here.
1. Remove the rubber feet
2. remove the screws from where the rubber feet were.
3. Remove the esata/usb base
4. remove the lower plastic cover
5. remove the tiny screws
6. remove the metal shield
7. remove the 3 base screws.
8. stick a standard screw driver into the lower holes and twist. One side panel will move, one will not. The removeable panel is the one with the logo that lights up. If you are looking at the drive from the back where the ports are, the panel is on the left.
9. Stick the screwdriver between the plastic of the panel that moves. this panel has 4 clips holding it on very tightly but it can be pryed off.
10. Once the panel is open, unplug the drive and remove it. It is in a metal free floating cage. Remove the rubber covers to reveal the screws.
11. Pry the two cage panels apart and the drive is free. There is no permanent damage to the case, so you should be able to mount another drive in it.
Jun 29, 2009 | Seagate Computers & Internet
Kitchen Appliances - Others Logo
183 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
