Question about Metra 99-5027 In-Dash Car Installation Dash Kit for 1987-1993 For
Metra 99-5027 kit - Metra 99-5027 In-Dash Car Installation Dash Kit for 1987-1993 For
I need a printable copy of the Metra 99-3303 for Chevrolet Malibu 2004-2007
Mr. Anony Mous,
Go to the Metra web site
http://www.metraonline.com/part/99-3033
Look under the picture of the dash kit and you'll see a pdf of the owners manual
http://www.metraonline.com/files/products/INST99-3033_web.pdf
I hope this helps, Ray
Mar 03, 2015 | Metra 99-3304 Chevy/pontiac/saturn/buick...
How do i replace my stock radio for a after market radio in a 1995 lexus sc400
There are several steps:
1. Take out the center cup-holder (it pops out with a little tug upward). unscrew the 2 screws.
2. On the shifter (lower part) there is a cover that covers 2 screws, unscrew and remove the shifter knob.
3.Take a pick tool and lift the shifter bezel console (black) it also pops up.. there are 3 or 4 connecters (disconnect with a small flat head screwdriver)
4. Once the shift cover is removed, there are several screws and tabs holding the bezel trim down unscrew the screws and lift bezel trim up,
5. Disconnect the ash-tray (blue connector)
6. Disconnect the hazard signal control , volume control connector and the climate control connector.( On the left side)
7. There are 4 screws holding the the radio and climate unit cage to the dash frame. (unscrew)
8. Now it gets a little tight, pull the unit towards you slightly and disconnect to connectors for the climate control unit (on top) and the factroy radio (on the bottom).
9. Next remove the radio and climate control unit from the cage(screws on the sides).
10. Next you will need a new cage: Metra 95-8157B Double DIN Installation Kit for 1992-2000 Lexus SC300 and SC400 (Black)
by Metra Link: http://amzn.com/B001TJG7SA
11. You will need the following harness: Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin by Metra
Link: http://amzn.com/B0002BEUBW and/or Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker by Metra Link: http://amzn.com/B0002BEQJ8
12. Match the wires according to the metra kit and new radio instructions.
13. Next follow instructions in reverse for re-stall. GL.
Feb 09, 2014 | 1995 Lexus Sc 400
Need to know how to install my deck in my 1999 chevy suburban
The best way to install an aftermarket stereo is to go to a stereo installation store and get the in dash "metra" kit and the wiring harness adapter that allows you to connect the aftermarket stereo wiring to the factory wiring on the truck...the "metra" kit adapts the aftermarket radio to fit into the space for your particualar vehicle..the tech at the stereo store will know what all this means if they know what they are doing...To clarify, "metra" is a brand name for these kits andthey also go by the name scoshe...
Jan 11, 2011 | Alpine CDE-7872 CD Player
I want to replace my Pontiac G6 radio. But I want to keep my "info center" display intact. Is that possible?
There is a kit from Metra called the Metra 99-3303 kit that takes the double din area of the stock stereo and converts it into an info center/single din. Cost is about $123 on ebay.
Aug 20, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
I want to install a dual xd5120 into my 97 camry. What kind of conversion kit will I need? And will it come with instrucitons?
You will require METRA pocket KIT
#88-00-8000
and
METRA Wire harness
#70-1761 (non-amplified factory radio)
or
#70-8112 (factory amplifier integration harness)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 18, 2010 | Dual XD5120 CD Player
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
What do i need to install after market cd player in my 2004 GMC Sierra?
The sad part about installing into alot of GM cars is that the Harness is about $100 bucks
You need a Metra GMOS-01
You need a metra 40-GM30 ( Antenna adapter, since the stock plug wont plug into after market radio)
And a Metra 99-2003 ( dash kit
Apr 06, 2010 | Pioneer DEH-P2900MP CD Receiver...
Im having trouble installing my double din alpine deck in my 2008 f-150. At one point I had everything installed and ready to go, But when I went to open the face to put a cd in the the monitor had trouble...
According to Metra you are using the right dash kit you just need to figure out the alignment for the radio. It will take some time but you will get it. Try to pull the head unit forward on the mount kit for the clearance.
Sep 25, 2009 | Alpine Car Audio & Video
Need Replacement Mast for Metra 44-PW22 Power Antenna
the online site for metra is www.metraonline.com The part number for the replacement mast is 44-PW22. Hope this site will help you find a dealer in your area. If you need more help, please ask.
May 18, 2009 | Metra Antennaworks 44-PW64
Metra 99-5027 In-Dash Car Installation Dash Kit for 1987-1993 For Logo
Top Metra Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
crkuc
Are you a Metra Audio Player and Recorder Expert? Answer questions, earn points and help others
