Question about Building Materials
I disconnect the des bayeria and they connect and the remote control did not work or if it was to open the doors
3 Suggested Answers
  • 244 Answers
SOURCE: Remote Control won't work.
How does everything look well? How old is unit? Did you push learn button for 10 seconds. Then pusj for 1 second and activate a remote button. lightbulb on motor should blink. if so, hit learn again for 1 second and push button on other remote. Do you have a LOCK or VACATION button. Make sure it is off . Is light on wall console blinking. you have remotes locked out.
Posted on Jan 15, 2009
rustym62
  • 201 Answers
SOURCE: remote control unit does not open the door. we
You can try reprogramming the remotes to the opener that is not working. Sometimes they get a brain freeze and drop the codes and reprogramming can fix it. Next to where the wire hangs down will be a colored square button (the learn button) press once and release, you have 30 seconds to try and program a remote, you don't need to do all in the 30 seconds. Press and hold the button on your remote that you want to use until you see the light on the opener blink or hear a click sound from opener, let go of the button. it should now be programmed. If you can't get any of them to work then the logic board is bad.This repair can cost as much as a new opener + install. Sears sells a "remote control conversion kit" it comes with 1 remote and a plug in receiver you attach to your existing opener. 2 wires come off it and hooks up where your wall control hooks up at the openr.It's pretty easy to install. FYI the remote controls are color coordinated meaning the buttons on the remotes have to be the same color or they won't work, so if existing remotes are not the same color as the one in the kit they will most likely have to be replaced. good luck!
Posted on Jul 05, 2010
I have an overhead garage door Legacy 496cb/d that stopped 3/4 of the way in the down motion. It now will not open or close and only clicks. The lights work and power is on.
If this picture at the link shown looks like yours, the red and white cord with the red plastic piece needs to be pulled to disconnect the automatic door opening chain.
http://www.aypapaquerico.info/overhead-door-legacy/overhead-door-legacy-large-size-of-garage-and-modern-overhead-garage-replacement-with-legacy-opener-overhead-door-legacy-496cd-b-manual/
Then, pushing the garage door fully open should move the mechanism back to connect in the ceiling. Then the remote control may work. If not, seek a repair service.
Mar 18, 2018 | Building Materials
How do I disconnect the keyless door entry on my 1996 Golf 1.4?
The alarm system needs to be de-activated by turning the key to the unlock position at the drivers door lock cylinder when re-connecting the battery. The alarm control module cannot be disconnected otherwise the vehicle will not start.
Feb 16, 2015 | 1996 Volkswagen Golf
My garage door opener opens on it own.
hi, this seems like a relay problem. internal relays in the control unit can get old and start connecting and disconnecting automatically causing the garage to open randomly. especially if you are in a high humidity climate.
You can either replace the control unit or send it to an electronics repair shop to replace the relays inside the control unit for you.
Dec 08, 2014 | Building Materials
Disarm car alarm without remote merc
I do know that if you put the key in the ignition after you open the door and cycle the key from off to on 3 times fast within 5 seconds the alarm will disarm. Whether or not it is for good is unknown since you have to lock your doors again at some point. Your remote is discontinued by Subaru, but the the newer remote for the 2005 to 2007 models will work on your car, unless you already have one. I hope this info helps!
Aug 30, 2014 | 2003 Subaru Forester
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Broken door handle - 2001 Nissan Quest SE
first you van order parts at discount from tascafordparts.com.
quest & mecrury villager are the same vehicle made at the same assembly plant. good luck to all. If you were in detroit area, I wold help you.
Trim Panel —Sliding Door Removal
  1. Remove the sliding door trim panel finish panel.
532ac84.gif 2. Remove the sliding door trim panel 2965fbe.gif Latch Remote Control —Sliding Door Removal
  1. Remove the rear sliding door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. If equipped, disconnect the sliding door power door lock actuator electrical connector.
  1. NOTE: Mark the position of the sliding door rear latch cable adjusting bracket before removing the bolt.
  2. Disconnect the sliding door rear latch cable.
  3. Remove the bolt.
  4. Remove the sliding door rear latch cable adjusting bracket from the latch remote control.
  5. Disconnect the sliding door rear latch cable from the latch remote control.
  1. Remove the 4 sliding door front latch bolts.
NOTE: If necessary, transfer parts to the new sliding door latch remote control.
Remove the sliding door latch remote control.
  1. Remove the bolts.
  1. Remove the sliding door latch remote control.
Handle —Exterior, Sliding Door Removal
  1. Remove the sliding door latch remote control. For additional information, refer to Latch Remote Control—Sliding Door .
  1. Remove the sliding door exterior handle.
    1. Remove the nuts.
Mar 08, 2009 | 2001 Nissan Quest
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
20 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
