Question about DISH Network ES161256 21.0 IR / UHF Pro Remote Kit for Receivers ES16
I need to program a zenith tv towork with the 21.0 ir/uhf pro remote control
  • 51 Answers
SOURCE: Draining batteries
probably caused by a short inside the remote, it will need to be replaced
Posted on Aug 06, 2008
  • 51 Answers
SOURCE: dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
  • 374 Answers
SOURCE: uhf pro 8.0
Problem has been resolved per customer.
Posted on Oct 06, 2008
  • 374 Answers
SOURCE: My IR remote no longer works in another room
Dawn,
If you want a remote that works via IR to control the satellite receiver you will need a IR only. The IR/UHF type only transmits signals to the receiver by UHF and the IR portion only operates the peripherals in the room such as the TV and VCR. There are some remotes that come with a kit that can change the remote to work as an IR only. I believe you have a TV2 remote and want it to work further away from the receiver particularly the room the TV is in. If this is the case you may have have to change the remote address of the new remote to match that of the old. You can do this by taking the number one remote and pressing menu-menu. Now take the new remote and press and hold the SAT button in the upper left of the remote until all lights across the top light up. Now key in the two digit number on the tv screen at remote address for tv2. Then press the pound sign and the SAT button will flash three times then press the record button and the TV2 icon should flash. Now you can cancell out of the screen on tv one and try the remote at the TV2 location. I believe this will fix your issue if not let me know. Thanks for using Fix Ya.
Posted on Jan 16, 2009
SOURCE: Dish 20.0 IR Remote works for awhile then it
I MAY have a solution!! We too have the VIP722 Dish Network receiver. Ours is the "K" model. I called the place where we purchased the TV and they said that the "brightness" on the TV may need to be turned down. He walked me through this, and it worked. The remote WORKS now!! Our TV is a 40" Sony Bravia that we purchased a couple of months ago. Evidently at night, the TV was so bright in the room, it interfered with the Infared Remote control. By turning down "off" brightness detector on the TV, the IR remote was able to send the signal to the receiver. Our TV is on a cabinet and the receiver is directly underneath on a shelf. I hope this solves your problem and anyone else's that may have this problem with the remote.
Posted on Mar 18, 2009
How to get the tv codes for sanyo tv model ds24425 to program dish network remote control 4.0 ir/uhf pro
Go to Dish network website, https://www.mydish.com/support/products/remotes/how-to/program-to-tvother. tells you how to program and the codes.
Jul 06, 2017 | Sanyo Televison & Video
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
How to program the UHF remote 153638 to link with the 106240. UHF/IR
you have to go to menu and look for the IR/UHF settings for the remote control and have it change to UHF, so that it would work for both remote!
Jan 24, 2014 | DISH Network IR Remote Control
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
I want to program my uhf receiver/ir emitter 106240
Oh boy. here is the problem. i have also a 106240 IR/UHF receiver/transmitter that changes the channels in the satellite box from another room so i can watch them in a second tv at channel 4. the original remote for the 106240 is broken and i bought another UHF remote #153638. So i need to program the new remote to work and link with the 106240 receiver, NOT the satellite box or the tv. Is there any expert here to enlighten us how can be done ? Very simple question :how to program the remote 153638 to link with the 106240. Thank you in advance
Oct 13, 2012 | Tivo Televison & Video
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
DishNetwork IR Remote Control Problem
First the only way the 6.3 will work is if it has the green number 1 on the tab facing you. Assuming this is the case you will need a new remote. This primarily is the remote for the second room away from the receiver. Thanks for using Fix Ya.
Apr 15, 2009 | DISH Network IR Remote Control
My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network IR Remote Control
DISH Network ES161256 21.0 IR / UHF Pro Remote Kit for Receivers ES16 Logo
20 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
