Question about Ridgid 34363 - Generator,Rdca7000
Ridgid rdca 7000 altenator cut out after 4385 hours of running time. reset button not working do i change whole altenator?
Can you please give advise on a problem with my bike it will start after putting on a fully charged battery then 2 hours later it will not it also runs sluggish even though i have changed the plugs
Have you checked your altenator? With a fresh battery it will run for a while but if your altenator dosnt work your battery will drain and bike will die. Also the bike is not made to run on a battery so if the altenator is weak or or bad you are not getting enough juice to your plugs , thus causing sluggish ride.
Jan 29, 2011 | Yamaha XJ 600 Motorcycles
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
My 12 volt Ridgid drill just quit alltogether. I know it,s not the battery or charger as I have an identical drill and it works just fine. This drill takes the small cartridge type battery. Any...
To start, I assume you took the "good" battery from the working drill and tested the inoperative drill.
Good for doing that.
The other causes I know of in Drills that turn them into paper weights are as follows:
1 Worn Brushed: You can attempt to test this by squeezing the assumed good trigger button and
Taping the drill or lightly banging it on a bench top or something else. If it is brushes, it will often but no necessarily all the time, start to run for a moment, or just running. Since you use the drill and "use it a lot" That will be the first thing I would look for.
2 Trigger Button.
I would bring it to a tool service place or send it back to Ridgid. Try this link
http://www.ridgid.com/Tools/Technical-Services/index.htm
Hope this helps, Happy New Year
Mark
Jan 01, 2011 | Ridgid 12 Volt Cordless 3/8 In. Drill
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
Drill shuts off
Yes, it's tripping on over temp. There is a thermal protection inside the motor. Try to not press so hard so the motor doesn't pull so hard. Let the drill do the work, and let it run at the set RPM. You will get more life from the battery and the drill motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ridgid 12 Volt Cordless 3/8 In. Drill
TIME CHANGE DID NOT UPDATE ON OUR CANON FAX MACHINE; NEED TO UPDATE TO 1 HOUR LATER
Press DATA REGISTRATION button and press the SET button 2 times. Press the DOWN ARROW and scroll to date and time and press button SET button. Enter the date and time and press the SET button when done and press the orange CANCEL key.
Apr 03, 2009 | Canon LaserClass 7000 Plain Paper Fax
Low volts light stays on
new altenator or junkyard one.if new return it, if junkyard just ignore light as its odds on they will not change it .the red light is caused by the difference in the voltage between input and output voltages .Quick test --start engine and run at 1500rpm disconnect battery and turn everything electrical on and if engine stops then change altenator if it stays running then altenator is OK
Jan 17, 2009 | 1998 Lincoln Town Car
CASIO TK 7000 cash register how to change the time
pgm 1
enter 24Hr Clock
0900 or 2100
press the date/ time button
next to the C Key on standard keyboard
Nov 11, 2008 | Computers & Internet
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Ridgid 34363 - Generator,Rdca7000 Logo
Top Ridgid Electrical Supplies Experts
Tim Venetis
Gene Haynes
obsteiner
Are you a Ridgid Electrical Supply Expert? Answer questions, earn points and help others
