Question about Lenovo 45J7918 750 GB SATA Hard Drive
Lenovo 45j7918 master - Lenovo 45J7918 750 GB SATA Hard Drive
I can't find any help for Lenovo Photo master. Help!!!!
Launch the program. Press F1 (which should pull up help). Search or browse help.
5 steps for editing the perfect photo with Lenovo™ Photo Master 2.0 ' Lenovo
http://blog.lenovo.com/en/blog/5-steps-for-editing-the-perfect-photo-with-lenovo-photo-master
May 30, 2017 | Lenovo Computers & Internet
Tip
Four Most Common Password Reset Solutions for Lenovo ThinkPad
<span> <p><img src="lenovo-thinkpad.jpg" />Lenovo ThinkPad Laptop password reset or recovery solution varies depending on which password you have forgotten. The hassle of<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-lenovo-thinkpad-password.html">Windows password reset</a><span> </span>process will range from simple inconvenience to total valuable data loss. For this, we have collected the most used Lenovo Computer password lost troubles and satisfactory solutions for you.<br /><b>Types of passwords for Lenovo ThinkPad Laptop</b><br />There are four kinds of passwords we will talk about Lenovo ThinkPad computer and the password reset solutions:<br /> <ul> <li>1&gt; Windows logon Password (Administrator, Domain and User account)</li> <li>2&gt; Supervisor Password</li> <li>3&gt; Hard Disk Password (Master and User)</li> <li>4&gt; Power-On Password</li></ul><br /> 1&gt;Windows logon Password for Lenovo ThinkPadWindows logon password for Lenovo ThinkPad is used to keep personal information private and we are always create some administrator or user accounts on Windows 7/Vista/XP PC and also domain admin or AD accounts on Windows Server 2000/2003(R2)/2008(R2). It will be a big besetment when you lost or misplaced the passwords of those accounts. However, with some easily password recovery ways, it is possible to re-access your Windows system with no damage of the data.<br /><b>Reset Lenovo ThinkPad Password with Password Reset Disk</b><br />If you are a cautious user, then you should have created a password reset disk for your Lenovo ThinkPad. So you just need to insert the password reset disk to<span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Lenovo ThinkPad password</a><span> </span>directly.<br /><b>Reset Lenovo ThinkPad Password with Available Windows Administrator Account</b><br />If you can log on as an administrator for your Lenovo ThinkPad with a right password, then you can reset any other passwords of your lost or forgotten Windows logon accounts directly.<br /><b>Reset Lenovo ThinkPad Password with Windows Password Recovery Program</b><br />If you have not created a password reset disk previously, or cannot log on as an administrator with a right password, and for this situation, like me, you still have option to reset lost password for Lenovo ThinkPad PC with third-party software.<span> </span><b>Windows Password Unlocker</b><span> </span>is such a powerful Windows password recovery tool which enables resetting windows 7, Vista, XP, 2000, 2003 and 2008 password as blank with 4 easy steps:<br />1. Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>from its official site with an available PC<br />2. Burn a bootable CD/DV or USB flash drive<br />3. Reboot your locked Windows computer from CD/DV or USB flash drive<br />4. Reset lost or forgotten Windows password for Lenovo ThinkPad with easy<br /><b>Reinstall Windows OS</b><br />Reinstall Windows operating system for your Lenovo ThinkPad will be the last choose if you can reset Lenovo ThinkPad password successfully with those workable solutions that have mentioned above.<br /> 2&gt; Supervisor Password for Lenovo ThinkPadA Supervisor password protects the system infor stored in the BIOS. The user must input the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to alter the system configuration. If the Supervisor password is lost there is no way to recover it to enter the BIOS configuration.<br /><b>Reset Forgotten Supervisor Password</b><br />A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To get access, you need reset the BIOS password with some solutions like locate the jumpers or solder beads, or just contact the computer manufacturer or motherboard manufacturer for resetting forgotten Supervisor password.<br /> 3&gt; Hard Disk Password for ThinkPad ThinkPadThere are two Hard drive passwords: a user Hard drive password for the user and a master Hard drive password for the system administrator. The administrator can use the master password to get access to the hard drive even if a user has changed the user Hard drive password.<br /><b>Reset Forgotten Hard Drive Password</b><br />If the user's Hard drive password has been forgotten, check whether a master Hard drive password has been set. If it has, it can be used for access to the hard drive. If no master Hard drive password is available, or if the administrator forgets the master Hard drive password, then the hard drive must be replaced. For this instance you just need ask help from your computer manufacturer to reset forgotten HDD password.<br /> 4&gt; Power-On Password for Lenovo ThinkPadAn Lenovo ThinkPad Power-on password protects the system from being powered on by an unauthorized person. When it has been set, a prompt will appear during the system start up, and the Power-on password must be entered before an operating system can be booted.<br /><b>Reset Forgotten Power-on Password</b><br />If the Power-on password is forgotten and the Supervisor password is known, simply go into the ThinkPad BIOS setup utility and reset the Power-on password, otherwise try the following:<br />1.Power off the Lenovo ThinkPad computer<br />2.Remove the battery pack<br />3.Remove the backup battery<br />4. Please power on the computer and wait till the POST ends. If the password prompt does not appear then the Power-on password has been reset.<br />5.Reinstall the backup battery and the battery pack.<br /><b>Note:</b><span> </span>Some ThinkPad systems have the ability to reset the Power-on passwords in the ThinkPad BIOS setup utility if a Supervisor password has been set.<br /></span>
on Apr 19, 2011 | Computers & Internet
When i turned on my lenovo R61e, it appears black screen with lock icon
this is the pssword protection, if you are enable to remember the pass, you can try to unlock the laptop with a master password:
try this:
http://www.biospassword.org/
or this web site:
BIOS Master Password Generator for Laptops
don't forget to vote my solution if it is helpful.
Feb 20, 2014 | Lenovo ThinkPad R61e Notebook
Polar RS200 does not sync using weblink. What should mic settings be on Lenovo T420?
Dear Jan, the link of master reset a RS200 is no longer working...Help!! do you know the steps?
Dec 27, 2011 | Polar RS200sd Running Computer Heart...
Master bluetoot
Just go to the Lenovo download center and see if they have bluetooth drivers for your laptop.
Mar 09, 2011 | Lenovo G460 14" i5-480M 2.66GHz 4GB 500GB...
I lost my bios password on my thinkpad t60 and i cant use it!!
You will need to contact Lenovo support. I used to be a certified Lenovo technician
800-426-7378
Mar 07, 2011 | IBM ThinkPad T60 Notebook
Hi i have problem in booting window 98 cd in my lenovo laptop. i want this because i want this for formating my leaptop with DISKMANAGER SOFTWARE but it not running the bootable disk.
in the bios you must enable auto detect for primary master, primary slave, secondary master and secondary slave if it is set to none your computer wont boot the cd.
i dunno what bios options they give you on your lenovo laptop.
is this a legitmate retail windows 98 SE disk?
if its a bootleg copy it might not be bootable.
don't forget to backup your data before you format
Apr 23, 2009 | IBM Computers & Internet
Lenovo 45J7918 750 GB SATA Hard Drive Logo
14 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
