Question about Kyocera Cell Phones
Event kyocera turns on but the screen is blank
When charger is plugged in it appears to be charging. When I turn it on, it starts up, then goes blank.
  • 83 Answers
SOURCE: Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Posted on Apr 26, 2009
  • 55 Answers
SOURCE: blinking red led while charging and tries to turn
This can be caused by the fact that you ran your battery so low that when its charging the phone tried to turn itself on but loses all power instantly and dies try charging the phone through the computer you might have better luck with getting it to run properly.
Kyle
Posted on Jul 09, 2009
  • 27 Answers
SOURCE: Blackberry Bold cannot charge and screen goes blank
1. You could have an OS problem or hardware issues.
Simplest first to troubleshoot the OS, by loading a newer, updated OS release.
http://www.blackberryforums.com/general-9000-series-discussion-bold/188088-latest-os-9000-4-6-0-451-4-6-0-266-multilanguage.html
2. If you can live without performing a backup of your device you can follow these steps to correct the issue:
1. Download the latest Vodafone UK firmware using this LINK (4.6.0.282)
2. Install the firmware onto your PC running BlackBerry Desktop Manager
3. Go to c:\Program Files\Common Files\Research In Motion\Apploader and delete the vendor.xml file.
4. Connect your device and open Desktop Manager
5. When prompted select "Upgrade Now" (If you are not prompted select Applications Loader > Update > If your device isn't detected remove the battery and connect the device > once the update starts insert the battery again).
6. Follow the prompts and your device will be upgraded.
Posted on Nov 05, 2009
SOURCE: Cell phone (Sony Ericsson W910i) turns itself off every 30 seconds
i have one too and it always turns itself off at least 15 times a day and a red light comes on at the back and the screen is blank. It hangs up on people half way through phone calls, and tells me i have messages wich i don't and comes up with blank messages which i can't delete!! Today it has done the exact same thing again but it has been frozen for over 3hours i have tried taking the battery out and nothing works :(
Posted on Dec 22, 2009
jennfolino
  • 6 Answers
SOURCE: my kyocera wont turn on. when i plug it in to
i have had several of these handsets and i have noticed that there are several batteries that will fit into the battery compartment of the phone, however just because the batteries fit, that doezn't mean that it is the correct one. i went online and ordered the battery for this phone model on ebay several times and everytime, i got the same result: the battery fit in the phone, i plug it in to the charger and the phone would light up and say: PHONE IS OFF **** it did not say phone is charging**** when i turned the phone on (with it plugged in) it turned on and everything seemed normal except the battery icon was missing from the right hand top corner of the display. i looked up the kyocera website and looked up the compatibility matrix and it was absolutely 0 help. finally i figured it out because i buy and sell phones on ebay and i received a used phone with the battery in it and it worked, the # printed under the barcode on the front of the battery is 020609606036. i also purchased a brand new handset that was still in factory packaging and i took note of the # on this battery also and it was the same as above but the last two digits are 35. i have not researched any other batteries for functionality on this handset, however, there may be more that do. these 2 OEM batteries i listed above do indeed work in the handset for sure
Posted on Feb 16, 2010
My Kyocera Event freezes on the Event by Kyocera screen everytime I try to turn it on. how di I fix this?
Hi!
I have a similar problem, but mine is complicated by the fact that I am trying to recover all my data ...
What I've discovered in my process may be of use to you.
If you're not worried about loosing all your stuff, and just want a phone you can use again, then this is the fix for you:
From off, start the phone with the on/off button '&' the down volume button at the same time (hold until recovery screen appears).
Choose the second option, "wipe data/factory reset." This will restore the software back to the original out-of-box condition.
I hope this helps.
Feb 26, 2015 | Virgin Mobile USA Kyocera Event
Kyocera event wont turn on but it will charge
Most likey a loose power supply connector or bad charger.
Aug 20, 2014 | Kyocera Cell Phones
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Phone will NOT power up on or off the charger but will tell me "phone is charging" and battery indicator will go up and down
You will need to replace your battery in your phone.
or check you charger and make sure it actually charging.
I would suspect it's the battery
May 28, 2009 | Kyocera wild card Cellular Phone
Sony mp3 walkman wont charge
i would get a new charger and go from there
Feb 26, 2009 | Sony Walkman NWZ-S616F MP3 Player
My kyocera
my thing charges but it is always white now. its sad. have you fixed it yet?? and suggestions??
Dec 28, 2007 | Kyocera Slider Cellular Phone
Cell Phones Logo
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
