Question about LG Refrigerators
Lg fridge temperature control
3 leds of the temp control are blinking and water is coming out of the fridge
    Master:
  • LG Master
  • 676 Answers
Please post your model number off the model tag on the refrigerator. Thank you
Posted on Feb 14, 2014
the dr
  • 447 Answers
SOURCE: Blinking temperature control
You need a new High Voltage Control Board.
Posted on Oct 11, 2007
  • 210 Answers
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Posted on Jun 07, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
aasc
  • 1606 Answers
SOURCE: GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Posted on Jul 23, 2009
  • 291 Answers
SOURCE: Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Posted on Jan 17, 2010
Testimonial: "Great info, easy to understand... hopefully the fix is as easy as the explanation!"
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Honeywell WV8840B1109 temp control valve on water heater. Status light @ 4 blinks between 3 seconds indicating "high temperature shutdown" even though lighting pilot with water cold. .
II have exactly the same problem: Honeywell WV8840B1109 temp
control valve on water heater. Pilot is on, but the burner won't
no matter how high I turn the temperature knob. Status light blink
4, which by the controller is "high temperature shutdown" and has
nothing to do with the problem. The real problem is that the
computer chip in the controller has gone bad. Problem is solved by
changing a new gas control valve/thermostat. The old Honeywell
control valve uses pure mechanical stuff and was very reliable,
almost never has a problem. I don't understand why they switch to
this new electrical one which use the tiny voltage generated by
the thermopile to run, easy to break, because of the electric
chips, and is more expensive. The only reason I can think of is
that they want to get more money from our pocket.
Nov 01, 2012 | Water Heaters
I have a Bosch ksu 44 fridge/freezer which has stopped working - just a click,click,click from the back and the control board led's flash with each click (1.5second intervals) - is it the control...
Very common problem on that fridge and a easy fix: Replace the two big capacitors on the right side of the control PCB 1uF = 0,68uF 250V They lost their capacity causing bad uC supply and this strange LED blinking. Be aware that this blinking can be intermittent and the fridge appears to return to operation. But the uC suffer a lot of internal resets causing intermittent operation stops, low temperature and more not easy recognizable or strange mal functions. So, if You face that blinking normally the capacitors are gone. Some strange and intermittent behaviors of the fridge are also back routed to this PCB - Capacitor malfunction. So enjoy this 30min fix. The capacitors should not exceed US$2 in Your local electronic shop. If You don't want to spend the US$2 You can find the capacitors as a lucky guy in a old PC power supply.
For other more complex problems be aware that the controller board has a very nice and helpful self test option. You go in this mode holding the temperature select button of the refrigerator (not the freezer button) then switch the fridge on and stay on holding the temp button for more 10s. The self test sequence starts in the moment when You release the temp button.
LED 1: Checking sensors (Blinking=OK - Continues=NOK, something wrong)
LED 2: The Flap opens and close two times (Alarm LED shows the open and close position, so the led must go ON and OFF two times in accordance of the detected flap position from the internal reed contact. (So, no action on the Alarm LED no movement on the Flap or a defect Reed contact)
LED 3: Fan goes ON and OFF
LED 4: Drain Heater goes ON and OFF
LED 5: De- Dicer Heater goes ON and OFF
LED 6: Compressor goes ON and OFF
LED 7: End of test sequence - Initializing procedure of normal operation.
Every step takes 30s and the whole sequence take tree and a half minute. Be aware that the alarm LED is no malfunction indicator. It has only the indicator function for the sensors.
The fridge goes in the normal operation mode when he passed the sequence. No further actions necessary.
Be aware that every time when the fridge faced a total power lost he makes a short silent 30s check sequence. If he face a malfunction (Sensors or actuators) he doesn't start the compressor anyway to protect the fridge for further damage!!! So, this test sequence is a nice tool to check that the fridge is in the right conditions to start the working and even so to check the compressor function before maybe a unnecessary replacement .
With a second build in test option you can select and activate devices in the fridge. For this You hold the fast freeze button and switch the fridge on. After 10s release the button and you are in a manual test mode. With the temperature button select the component - Push the Fast freeze button to activate or deactivate. For example: Select LED6 (Compressor) with the temperature button, push the fast freeze button for ON and OFF. But I ask You to be careful on this test mode to avoid further damages. For example a blocked motor that You should release better by hand than blow up by a tricky fingertip. Enjoy this fix and feel free for Crtl C + Crtl V.
Jul 04, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Air conditioner will not stay on a selected temperature in cool mode for more than 3 seconds. For example, you can change the temperature to 70 degrees and it will blink for 3 seconds and move back to 88...
Don't you just hate electronics? The control might be sensing a bad thermostat. Especially considering that the manual says that the max temp is 86 (not 88).
Jun 03, 2011 | LG LP0711WNR Portable Air Conditioner
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
Water not coming out of door dispenser. Have to go inside and use Hair Dryer on the inside water lines on the back wall of fridge behind the vegetable draw to thaw. Fridge is set at recommended...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
100 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
