Question about Hotpoint HSS25GFP Side by Side Refrigerator
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Fuse on board appears good
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 650 Answers
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Posted on Feb 14, 2014
SOURCE: water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Posted on Jul 07, 2007
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
SOURCE: Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Posted on Mar 07, 2009
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
Hsm25gfra sa. Bought used, was told ice maker didn't work, so haven't hooked any of that up. Problem: water/ice is pooling in the bottom of the freezer section. Every day or two it leaks out. I'm...
The refrigerator has a blocked condensate drain line. In most Hotpoint models it is easily accesed by pulling out the bin at the bottom. There should be a drain grommet at the center of a trough in back. This plugs up. You may have to pour hot water the thaw out the ice and then either blow out the drain tube or I use a 5/15 plastic hose and push it through the drsin to clear it out. this should fix the problen for a long time. Food particles etc. collect in the drain and ice forms around them and blocks the drain.
May 17, 2014 | Hotpoint HSS25GFP Side by Side...
Hsm25gfre sa
u need to replace the water inlet value
Apr 06, 2014 | Hotpoint Refrigerators
Hi the icemaker stopped working. the cold air is still blowing but no water. not sure what new parts to order. whirlpool model # ED5FHEXNS00. Please can you advise!!
It could be your ice maker itself, as a small clock type motor rotates a cam that operates a micro switch that then operates a water solinoid valve for a certain period of time to fill the ice tray. It could be the solinoid as that is a electro magnet with a coil of wire that could go open. Check to see if the vanes in the ice maker is actually turning. The ice maker is sold as a unit that fits most boxes, as that is pretty universal in most refrigerators. It is held in place by two clamp screws and connected via a harness.
Feb 04, 2011 | Whirlpool ED2KVEXV (217 cu ft) Side by...
The ice maker has stopped making ice.
first check the water supply on the ice maker check inlet water solinoid valve then reset the unit by unplugging power cord after a minutes plug the unit and start ice maker see to it that the compressor running.
Jan 23, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
ICE MAKER NOT GET WATER
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...the temperature(it needs to be 0-4 degree F for the ice maker to start) may be defrost problem send me a note if you need info on that
Aug 24, 2009 | Amana SXD524VW Side by Side Refrigerator
I have a GE Hotpoint Side by Side refrigerator Model #HSM25GFRA SA and have a problem with the water dispenser. I've switched out the filter with two new ones but still have the same problem - no water...
Alot of the GE refrigerators have problems like this. You either need to replace water valve on the back because one of the valves has stopped working OR the tube in the door has frozen and the door will need to be replaced. The best way to tell is remove the hinge cap on the bottom hinge and disconnect the little adapter put a towel down there and then trigger the water dispenser. If water comes out, the tube is frozen in the door. If not, replace the valve.
Jul 15, 2009 | Refrigerators
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
105 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
