Question about Boss CH350 Car Audio Amplifier
Wiring problems for my high inputs on my boss choas ch350
How to wire my high inputs
Should just be LR+ LR- RR+ RR- and a ground...
Posted on Oct 30, 2007
I have a boss 400w riot 2-4 channels,how do i connect the high level wires? Because stereo doesn't have rca's
to use the high level leads, you have to isolate the wires going to each speaker (if using 4 channel mode) or isolate the wires going just to the rear if you are using 2 channel mode. you have to strip a small piece of the insulation off each speaker wire, and run it into the amps high level input harness. if you dont have the high level input harness, you can get a 2 channel high level to rca adapter for around $20. basically, you are tapping into the signal to the stock speakers to feed music to the amp. make sure you get all your positives and negatives correct. brighter wires are usually positive; however you may be faced with sa speaker which uses a grey wire, and another grey wire- the second with a black line. you will have to, again, turn to internet research to determine which is positive and negative, if the colors are not obvious.
Dec 30, 2016 | Boss Car Audio & Video
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
Hi i have a boss dvd in dash 996b in a 2002 nissan altima....always worked good ..i wired the pink wire to the fram to ground out ...always worked...i open dvd to watch movie and display shows NO VIDEO...
have you tried a different video input such as a video input behind the radio. have you made sure that you are playing dvd and not video in. or the boss unit could be broken.
May 05, 2011 | BOSS AUDIO SYSTEMS Car Audio & Video
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
I would like to hook up my boss br 900 cd and a digitech vocalist 2 to my fender passport 250 could you please help me. Emery
1st connect the digitech vogalist
(Line Out L/R)
output to one (line input) from boss br 900 and the boss (line output) to the passport (stereo input) use a high quality cables, to supress noise efect, on output.
Jan 08, 2010 | Fender Passport P-10 Professional...
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
I need to know how to install a Boss Audio
Hello viperman2004,
Just connect your speaker leads to the input of the B65N (gray and gray/white pigtail leads), run the RCA cables to your amp (red=right) inputs, adjust the left and right level controls to match the amp input without distortion, and mount the unit.
Hope this helps.
Aug 11, 2009 | Boss Car Audio & Video
How to install a 7 band boss eq with no high input jacks
If you are using the low input to put high input in you can use a 22k resistor and a 10uf capacitor connected in series to the plus side of the speaker wires. This will bring down the signal level from the speaker to low input level and you will have a nice distorted free music.
Boss CH350 Car Audio Amplifier Logo
35 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
