Question about Baxter Ovens
Were i can buy the computer board
The oven does not start and the problem is the computer board whre can i get it
    Top Expert:
  • Baxter Master
  • 76,846 Answers
Try ebay.
Posted on Feb 14, 2014
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Oven turns on starts to heat then shuts off, no error code given just sais fault
Sounds like your control board is failing. I would suggest having it fixed before the damage becomes beyond repair. Many companies like to discontinue their parts in 3 years or less so if the control board becomes non-repairable you might be stuck buying a new oven. Therepairshack.com offers a repair service for whirlpool control boards. Do you have a model number? I can check to see if there is a replacement available also.
Dec 02, 2015 | Whirlpool WOS51EC7AW Single Wall Oven...
Ge jkp15aa
Take the back off the control panel and see if you can access the board. If you can see the board component side, go to radio shack and fgget freeze spray. Start the oven and when it quits like you described, spray one part on the board at a time till it comes back on. OR buy a new board
Feb 07, 2013 | GE JKP15 Electric Single Oven
The temperture pilot light will only come on when the oven door is open.So therefore in the oven will only heat up when the door is open. close the door and the temerture pilot light goes out The clock has...
Problems like this are almost always control board related and are the result of a power surge/spike....
Replacing the control board should solve your problem...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | AEG B8139-4-M Electric Single Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
There is a beeping sound and F1 shows up in the display
These errors generally mean the control board has failed in one or more ways. F1 is by far the most prevalent. When this happens you need to replace the control board. You may be able to buy a new board or have us (www.fixyourboard.com) repair it (particularly useful if the board has been discontinued by the manufacturer). We have many DIYers who remove their control board and send it in for repair.
On some models it is possible that F1 could also be caused by a keypad problem. In this case it will specify in the tech sheet to power down the oven, disconnect the keypad then power the oven back on, wait for a few minutes to see if the error reappears. If the error reappears it is definitely the control board. If not, it is probably the keypad but be aware that F1 usually starts out as being an intermittent fault, then gets more prevalent with time.
In the Jennair case you need to send the clock, relay board (2 for double oven) and connecting cable that hooks them together. All 3 (4) have potential F1 failure sources.
Aug 05, 2010 | Jenn-Air Electric Double Oven
Kenmore model 790.9621 electric stove error code F10. The oven heats up on bake (set at 400 degrees) then goes into f10 mode; and seems to be heating up more. Answer for problem??
it is the bake relay sticking--on the eletronic oven control board.i tried to buy the relays but,no luck.must buy the eoc board-great engineering
Jan 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
OVEN WILL NOT BAKE , IT WILL BROIL
I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Dec 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Oven does not start
This is an update from James758. When I pressed the temp sensor probe and wiggled it a bit, sometimes the oven would work, but then it failed permanently after a few days. Had to call a repairman who charged $325 to replace the entire electronic panel and the separate sensor, although the failed part was only a relay on the board according to him. He also found a pinched wire when he pulled the oven out (one new electronic board relay failed when he first replaced it). Don't know how the wire to the sensor got pinched since the oven worked for 8 years without us moving that hidden wire. By the way, buying the sensor at a parts store in town was $18 versus his cost to us of $49. I'm sure the electronic board would also be much cheaper online. My wife watched the repairman replace the parts; you can save a lot of money doing it yourself.
Nov 14, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
55 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
